hi i transfered the thread to here because i hope i can get more support
the scratching only happens when in rear gear...
i don't know..what would you suggest me to do ???
i mean for the 1.6ZM there seems to be no other strut that fits it correctly (length,holes) but the bar must be somehow modified because i don't want it to hit the manifold anymore...
cansavem suggested to soemhow grind down the manifold, but i don't think this is acceptable.... (nervous)
does anyone know a solution maybe ? some brainstorming ?
------ my first post was ------
hi there.. today i got my car lowered with eibach prokit and the oem p5 strut bar that i got from canada was also installed...
the problem was that the ZM engine is sitting "too high", so the strut touches it when it's installed...this is not good when the engine moves(loser)
so the mechs put a wooden wedge between the strut and the gasket,took some steel bar and levered/bent the the strut a little more upwards with HUGE POWER... the whole engine went up and down while they did this and finally they got 1/2cm between bar and engine... damn, i almost pissed my pants when they did this... but now it seems to work..
just to let you know (i know there is at least one other p5@ZM guy here
i will take fotos later..
