OK quick question. A buddy of mine bought a protege not too long ago and took his car up to the dealership @ 1500 miles to get the oil changed. The guy at the dealership refused to change the oil and said if you change it before 5000 miles, you will have problems down the road with the seals. Supposedy he said that the engine is supposed to run with the same oil for 5000 miles to seal the engine better. btw... he didn't say that the engine had a "special" oil or anything... i believe he said it was normal oil.
My question is.. have you guys ever heard of anything like this? My p5 is at 1500 right now and i was planning on changing it. Then i was going to change it again at 3000. After that, every 3000 miles. I was just asking to make sure i haven't been under a rock all this time and see if this is BS or actually valid reasoning.
Thanks,
Dale.
Thanks,
Dale.
