i have enkin 17 inch rs6 rims with if i remember right Falken 512 All season Ziektires , whats the recomended tire pressure on low profile tires like that, i keep my at 32 psi should i add more?
No you are probably just fine.....the tires you have put on are not that much different than the stockers....you can run the same presures as the stock recommended tire presures and be so close to the optimum presure you won't be able to tell the difference.
