yet another crossbar question
shelton
the front crossbar support on the pr5, does it attach with only one bolt on each side and does it just sit on the metal piece with the hold drilled in it or does it sit on that metal piece with a washer or bracket underneath?
Thanks.
Brian MP5T said:
4 Nuts, 2 on each side...
are you sure? There is only 1 mounting hole on each side of the front crossbar??? Does it just lay on the metal piece underneath (ie: metal on metal) or is there a washer under there?
oh you canadians didn't have the roof rack huh. it's just one bolt on each side for each i think, I put all the parts in a plastic bag when I took mine off and I only have 4 big bolts.
If you look at my car you will see that putting s*** on my roof would be as appealing to me as putting people in the backseat.. :(
