I just purchased the Kenwood KSC-WA82RC powered sub to up my bass for cheap, and I have some questions on the install...
The terminal connector on the power cord that goes to the battery isn't the usual ring terminal but instead a metal male piece that has an open-ended clear plastic sheath. In fact, all the connectors are like this, either female or male, except the ground, which is a spade. Do I need to replace the connector on the power cord with a ring or is that one fine?
Secondly, and this question is probably a little more newbish, but where along the rear speaker wires should I tap into for the speaker inputs? If it's anywhere along that wire, I could just strip back the rubber coating and wrap speaker wire around the exposed part, right?
I have an '03 Protege sedan and I'm using the stock unit with the stock speakers. I entertained the idea of RCAs, but the stock headunit would need an LOC, correct?
Oh, and just to confirm the remote turn-on goes to Pin 10?
