In Memory of Member 1338
Page 5 of 27 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 397
Thread: ** Spring Buyer's Guide **
  1. #61
    Registered Member iON Performance's Avatar
    Potential Scammer!
    Join Date
    May 2003
    Location
    Calgary, Alberta, Canada
    Posts
    797
    BlueWolfCry - for your application if you want to use the stock struts for now, the sport specs will allow for better ride comfort and handling compared to the race spec on stock struts.
    Both springs will offer performance benefits to the car, it depends what you're after. The sport specs will still have the practicality of extra ground clearence vs. the race spec, and for a street car that would be idea. On the P5 we've had customers load their cars up fully with 5 people w/ luggage on the sport specs that the car still handled like the way it's suppose to with the sport spec springs. The following are some pics of the sport spec on the P5 to give you an idea. You'll be able to get away with using the sport specs now on your stock struts, and then upgrade them to better units when you have more money.
    iON Sport Spec front springs vs. OE Front Springs
    iON Sport Spec rear springs vs. OE Rear Springs
    iON Sport Spec Springs Installed (front view)
    iON Sport Spec Springs Installed (side view)
    iON Sport Spec Springs Installed (rear view)
    iON Sport Spec Springs Front Right Fender Gap
    iON Sport Spec Springs Rear Right Fender Gap
  2. #62
    Turbo Addict Black Majik MSP's Avatar
    Donated: $30
    2003.5 Titanium Gray MSP #1699
    Join Date
    Aug 2003
    Location
    Weston, FL
    Posts
    4,133
    I'm getting my new wheels tomorrow & after that I still need to get motor mounts, but iON race springs are next on the list after that.
  3. #63
    mx3ownzj00 low_psi's Avatar
    Donated: $10
    ms|slowtege #399
    Join Date
    Feb 2002
    Location
    Ft. Worth, TX
    Posts
    7,106
    Quote Originally Posted by goku4658
    ok mx3ownzjoo, yet another question...i was all set to order the eibach pro's for my msp...but got tempted to consider the tein s-tech springs and the falken gravity sport springs cuz of the greater front drop....what are your opinions between these 3? been a great help so far, thanks!!
    -jon
    my BIASED opinion is:
    pro-kit: performance w/ a fair drop
    s-techs: nice drop but I've heard too many reports of them being too soft.
    falkens: i'll stick with their tires. i doubt performance will be increased, but if all you want is a stylish drop, I'm sure you'll be happy.
    whoops, I'll double check the drop for the s-techs again. maybe I did reverse them. thanks for the heads up.
    thanks for stepping up and answering everyone's questions iON! j00 rawk!
  4. #64
    Registered Member dmitrik4's Avatar
    '04 RX-8 || '10 CX-9
    Join Date
    Aug 2002
    Location
    Phillies-delphia
    Posts
    2,365
    mx3:
    just wanted to add another suspension option from mazda motorsports (for members)
    COIL OVER KIT
    PROTEGE
    1.8 DOHC, 2.0 DOHC
    1999-2003
    $1,395.00
    P/N: 0000-04-3300-KT
    Notes:
    Includes new AWR manufactured front strut housings, threaded collars and spring perches for front and back, Bilstein inserts, 275lb/10" (front) and 325lb/10" (rear)Eibach ERS race springs.
    mike #44 CS
    '04 RX-8 - daily and racer
    '10 CX-9 - family truckster
    www.GreyhoundAngelsAdoption.com
    www.phillyscca.com
    Quote Originally Posted by Jalopnik
    We'd rather be taken out and shot behind the storage shed than spend $28,000 on a perfectly competent automobile that delivers very good fuel economy.
  5. #65
    Donated: $10
    ms|slowtege #399
    Join Date
    Feb 2002
    Location
    Ft. Worth, TX
    Posts
    7,106
    Sweet. I'm going to update the guide before the 11th. Thanks for the info.
  6. #66
    Missing my Protege vindication's Avatar
    Donated: $10
    2001 Pro 2.0 LX
    Join Date
    Feb 2003
    Location
    Formerly in NY, Now in Portugal!!
    Posts
    5,050
    I don't know if this was stated earlier and it was not on the chart but, B&G has springs and coilovers for the P5 and sedan also. Might want to check up on that.
    It's like I'm smoking their thoughts.
  7. #67
    I Love My Car, hate Mazda TrueProtege's Avatar
    2003 Protegé5
    Join Date
    Apr 2004
    Location
    Ontario, Canada
    Posts
    53
    Has anyone put the MSP springs on the P5? I can get a set of them for cheap, but I don't want to waste my money if it dosn't lower my car.
    MECP Cert. Installer
    2003 Laser Blue Protegé5
    Alpine IVA D300 source
    Sony XM-7557 amp
    Focal 165V3 component set
    1-10" Alpine Type-R (ported)
  8. #68
    No Heat bonesmp5's Avatar
    Protege5
    Join Date
    Feb 2004
    Location
    Portland, Or
    Posts
    1,504
    http://www.ajusa.com/cgi-bin/bg/star...ge%2F+Protege5
    I'm putting this here just in case someone needs the info -- the front spring rates are 280lbs and the rear are 224lbs --
  9. #69
    Donated: $10
    2001 Pro 2.0 LX
    Join Date
    Feb 2003
    Location
    Posts
    5,050
    i've founf them for $900
  10. #70
    Protege5
    Join Date
    Feb 2004
    Location
    Portland, Or
    Posts
    1,504
    ya they have different prices -- but i was just giving the spring rate since most the sites that i have seen dont have them
    Quote Originally Posted by vindication
  11. #71
    Banned nictlg7's Avatar
    2003.5 Titanium MSP, 2000 Mercury Cougar ST200
    Join Date
    Nov 2003
    Location
    Orange County, California
    Posts
    261
    If anyone cares to know, I have Eibach Pro-kit springs on my show car. The ride is definitely rougher than my stock setup, but that is because it is a Mercury, a European designed car, meant to be a very smooth handling car. I used to be able to drive it 140 MPH on the highway and not even realize it, it was that smooth. It is actually still smooth at high speeds, but if you hit a slight bump, you do feel it. However, I wouldn't say it is a rough ride, compared to many other suspension setups I have noticed in friends cars. My car does not bounce like many lowered cars. It is tight, I can take sharp turns @ 70 MPH with no tire noises or lean. I do have strut braces on the front tower, and a full ST200 (European special edition) rally style brace in the rear (including a cross member). My point is that the ride quality was not quite as smooth as stock, but handling and cornering are so much better, it far offset any comfort losses. I think I would go with Eibach on the MSP unless I ride in a car with something better. I want something that rides nicely for daily driving, but will allow me to corner like I do with the show car. My next step will be the Corksport trunk braces once I drop the car a bit. I only want to drop it 1" to 1.5. MazdaSpeed and Eibach actually make a set of springs that should work perfectly for what I want. CorkSport sells those also. Man I should work for those guys. I always am selling stuff for them...
  12. #72
    Donated: $30
    Join Date
    Aug 2003
    Location
    Weston, FL
    Posts
    4,133
    Quote Originally Posted by TrueProtege
    The MSP Racing Beat springs will lower a normal Protege 3/4", but I'm not sure if they work on the P5 (I think the rear setup is different). I'm sure someone else could tell you.
  13. #73
    Donated: $30
    Join Date
    Aug 2003
    Location
    Weston, FL
    Posts
    4,133
    Quote Originally Posted by nictlg7
    Just better handling or better mix of handling AND ride comfort?
  14. #74
    Registered Member Reitrof's Avatar
    Donated: $50
    2008 Miata PRHT; 2018 3
    Join Date
    Jan 2003
    Location
    Ottawa ON
    Posts
    7,526
    What about Tein H springs? I heard they lower less and have a more stock like ride?
    Bruce
    2008 Miata Touring PRHT True Red, MazdaSpeed body kit
    RB Intake, RSII Exhaust, RX8 Sways, KW V3 Coilovers, Fiaam horn
    RX7 FD Rims, Kenwood DNX7100, Int Wiper Mod, 3M Bra
  15. #75
    Registered Member srtchick's Avatar
    2004 Silver SRT-4/06 STI
    Join Date
    Aug 2003
    Location
    VA BEACH
    Posts
    1,187
    now i have been thinkin aobut gettin the tein s-tech springs.. since i have a sub in the back already is tucked do to the weight.. could i order the tein & just use them on the front or no ?
    2006 Subaru STI
    2004 Dodge SRT-4 270hp 290tq~> FOR SALE
Similar Threads
  1. BUYER'S GUIDE: SRT-4 VS MSP.
    By AustinG in forum Mazdaspeed Protege
    Last Post: 06-20-2004, 10:48 PM
  2. how do i lower a p5 with out losing handeling
    By mp5drift in forum Mazda Protege
    Last Post: 10-21-2003, 01:42 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
