Page 4 of 4 FirstFirst ... 234
Results 46 to 54 of 54
Thread: How to: Replacing A/C Control Panel LEDs
  1. #46
    Zoomin' since 2003 KMac's Avatar
    Mazda Protege5, 2003.5
    Join Date
    Jan 2003
    Location
    Rainier, Oregon
    Posts
    271
    If you go to Zapwizards website you can actually still send him a note about this mod. I did earlier in the year when the links to the pictures were broken.
    Stock 2003 P5 129k miles
    Mods - Speed6 Wheels, Powder coated Valve cover.
    Wanted - Double din Nav with DVD to headrest for the kids (12 and 9), MS6 Big brake conversion. Mazdaspeed6 18's.
    (p5blue)
  2. #47
    Registered Member
    2002 Mazda Protege LX 2.0
    Join Date
    Sep 2012
    Location
    New Brunswick, Canada
    Posts
    2
    Hi, I'm about to do this mod and am wondering how you wired your Blue Led?
    Thanks
  3. #48
    Tuned by Slick Nick FunkyBuddha's Avatar
    2003 Spicy Orange MSP
    Join Date
    Feb 2003
    Location
    Calgary, Alberta, Canada
    Posts
    7,190
    I'm having issues removing the cable on the driver side. The metal clip won't budge. Any tips or tricks to remove this?
  4. #49
    Registered Member
    Mazda 323F, 1.6, 2003
    Join Date
    Feb 2015
    Location
    Baia Mare, Romania
    Posts
    2
    Radio lights
    Quote Originally Posted by ZapWizard View Post
    This is my first step towards a completely red control panel.
    Next hopefully will be the radio backlights.
    Hello,
    My name is Mihai and I am new to this forum. I have recently bought a Mazda 323F, 1,6, from 2003.
    I noticed that my radio has all the buttons lit up in red, but one. Namely, the "CLOCK" button, which is not lit at all. In the pictures of your radio I saw that this button is also lit (in green in your case). My question is, how can I replace / fix the light of this button? I would like to see all of them at night. Is there a back light for this button or not? Are they lit individually? Thank you.
  5. #50
    Asian Persuasion <>< Hank3's Avatar
    Contributor
    2010 Mazda5 GT | 2014 Kia Soul !
    Join Date
    Oct 2002
    Location
    Tallahassee, FL
    Posts
    4,649
    Reviving this thread for posterity's sake as I just switched out the two bulbs last night for the HVAC/AC climate control. If you don't want LEDs the stock bulb replacements are #2723 and can be found at your local Advance Auto for $5 for a pack of two. #2721 are the same size and fit, too, but the wattage is less and just simply wasn't bright enough for me.
  6. #51
    Registered Member booom's Avatar
    2002.5 Protegé5
    Join Date
    Jul 2004
    Location
    Los Angeles
    Posts
    319
    Re-reviving this thread to share LEDs I used to replace the burned out bulbs.
    74 LED Bulb - 1 SMD LED - Miniature Wedge Retrofit - Red about $7 shipped for a pair.
    After I untwisted the bulb seat from the panel, I removed the burned out bulb, of course, and pushed in the LED which was a tight fit. It was a little too tight of a fit as the wedge bulb spread the seat out too far which prevented it from fitting back in through the hole on the panel. So, I removed the LED bulb and then placed the seat back into the panel and twisted it in without a bulb. Then, from the front, with the seat locked in place, I pushed/stuffed the LED wedge into the seat. I went straight for this method on the second one but found I wasn't able to just stuff the LED bulb in from the front. I had to remove the seat and stuff the LED bulb in to pre-condition or stretch the seat. Then I repeated the process and the bulb went in albeit tight.
    Another tip, if they don't light when testing just pull the bulb out and flip 180 degrees to correct polarity direction to then instantiate lased light emissions!
    Also, the Kenwood KDC-BT362U can be configured to display entirely in the color RED
  7. #52
    Registered Member
    2002 Mazda Protege 5
    Join Date
    May 2012
    Location
    Hollywood
    Posts
    66
    Do you know where the thread is to fix the AC switch?
    It seems only position two and full on works for me...
    thanks
  8. #53
    2002.5 Protegé5
    Join Date
    Jul 2004
    Location
    Los Angeles
    Posts
    319
    Quote Originally Posted by PaulyD View Post
    thanks
    This is the thread where you can dig up the permanent fix: Solution to flickering fan speed
    The cheap/temporary fix is to remove the fan speed switch and clean the copper contact points or just replace it with a new one from ebay for a cost $20.
  9. #54
    2002.5 Protegé5
    Join Date
    Jul 2004
    Location
    Los Angeles
    Posts
    319
    Quote Originally Posted by booom View Post
    See thread Solution to flickering fan speed post #277 by pb4ugotobed for instructions and pics
Similar Threads
  1. How-To: Disabling Automatic A/C - Defrost modes
    By ZapWizard in forum Mazda How-To
    Last Post: 12-13-2016, 06:34 PM
  2. A/C Compressor Cycling?
    By CentralPAZoom in forum Protege5
    Last Post: 08-23-2016, 01:05 PM
  3. Control Panel: Wrong section highlighted
    By ATLskate in forum M247 News & Support
    Last Post: 09-20-2003, 04:16 PM
  4. replacing quarter panel glass....
    By Dexter in forum Lounge
    Last Post: 09-03-2003, 06:11 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
