Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 54
Thread: How to: Replacing A/C Control Panel LEDs
  1. #31
    i've nothing to type here blynd_spy's Avatar
    2003 LX
    Join Date
    Aug 2004
    Location
    seattle, wa
    Posts
    513
    yeah im trying to snake an led on the side. Just use a 220 ohm res?
  2. #32
    Electro-modder ZapWizard's Avatar
    Join Date
    Jan 2004
    Location
    Austin, TX
    Posts
    208
    Quote Originally Posted by blynd_spy
    220 should be about right.
    I will be modding my wife's car with blue LEDs and I may redo the guide with more detail on the general backlighting then.
    www.ZapWizard.com
    -Advanced Computer Modification-
  3. #33
    2003 LX
    Join Date
    Aug 2004
    Location
    seattle, wa
    Posts
    513
    cool, thanjs for the help
    another quick question, in the attached pic I circled the two wires i fried and ran jumpers...would this in any way contribute to my heater not producing heat? Havent troubleshot the problem yet, but pretty sure its not the flap.
  4. #34
    N.E.P.O.C. Protege52003's Avatar
    Donated: $5
    '08 Jetta; '10 Wrangler Unlimited
    Join Date
    Feb 2003
    Location
    Mass
    Posts
    7,829
    If you do this, this would be a good time to fix the AC problem being on when you have the defrost mode on.....kill two birds with one stone.
    /forum/showthread.php?t=55382
    good write up.......
  5. #35
    Banned Dexter's Avatar
    Donated: $5.73
    Unauthorized DOUCHEBAG
    Join Date
    Sep 2002
    Posts
    11,960
    that board has nothing to do with controlling the heat. it must be the manually driven part.
  6. #36
    2003 LX
    Join Date
    Aug 2004
    Location
    seattle, wa
    Posts
    513
    thats kinda what i figured..just wanted to make sure before i tear things apart. The control arm for the heat seems to be functioning properly...what else could be keeping the heat from coming through..fans are definitely fine btw.
  7. #37
    Registered Member Dark Wanderer's Avatar
    Protegé 01 1.6L
    Join Date
    Dec 2005
    Location
    Quebec (Canada)
    Posts
    12
    Were Did you take the 2 10mm 12 volt Leds?
  8. #38
    Registered Member xnager23's Avatar
    1999 Protege LX
    Join Date
    Apr 2004
    Location
    Montreal
    Posts
    8
    You are probably not getting any heat because u might not have installed the cables (from the unit to the air ducts) correctly. For the temperature control cable, when u clip it back into position make sure you use the clip that is on the duct unit. My clip fell off and i either have full heat or no heat (have to change it manually). Mazda has the clip for $2.50 (Canadian Dollar)
  9. #39
    2003 LX
    Join Date
    Aug 2004
    Location
    seattle, wa
    Posts
    513
    thanks, but yeah i fixed that the same night. Clip wasnt on the plastic piece and didnt feal like posting my stupidity.
    Sure would have been a cold winter of 2005, thats for sure..
  10. #40
    Registered Member
    Join Date
    Jul 2006
    Location
    Ms. Jackson
    Posts
    3,361
    when i try to remove my center panel thingie, it seems to be held on by the ac knobs at the bottom, and they seem to be screwed on the back of it, and the space is very tight to get a screwdriver behind it. ill post pix if i have to. im trying to paint the center panel.
  11. #41
    2003 LX
    Join Date
    Aug 2004
    Location
    seattle, wa
    Posts
    513
    you just need to disconnect the harness, there are two of them. Also need to disconnect the cables that connect to the flap controls on each side and two metal clips that hold them in place. Then the radio bezel will come out with the AC controls attached, then you can remove the AC controls easily and paint away
  12. #42
    Registered Member
    Join Date
    Apr 2005
    Posts
    12
    Note: If Backlight goes out on your protege5 (mine is 2003.5) the backlights are not LED's. They are a replacement bulb that fits into a push and twist socket. You must remove the bulb and bring it into a car parts store. It should be a 2721 instrument/courtesy bulb. 12V.
    Total time without running to find the bulb: about 1.5 hours to take apart and put back together the console.
    Have fun with the cables!!
  13. #43
    Founding Member of CPC 90210brandon's Avatar
    Donated: 10$
    Join Date
    Apr 2003
    Posts
    660
    I wish all How-to's were this in-depth.
    Zap is a king.
  14. #44
    Your car sucks. xDJ DUBx's Avatar
    Slammed Thread President
    Join Date
    Jul 2007
    Location
    High Desert, CA
    Posts
    10,831
    4 yr old post. lol.
    I'm scared to do this.
    R.I.P. The Slammed Thread 2009-2012
  15. #45
    Registered Member
    2003 Protege5
    Join Date
    Apr 2011
    Location
    Red Deer, Ab
    Posts
    31
    Will any old 5mm LEDs work? If it doesn't matter I could try this mod out right now. Thanks
Similar Threads
  1. How-To: Disabling Automatic A/C - Defrost modes
    By ZapWizard in forum Mazda How-To
    Last Post: 12-13-2016, 06:34 PM
  2. A/C Compressor Cycling?
    By CentralPAZoom in forum Protege5
    Last Post: 08-23-2016, 01:05 PM
  3. Control Panel: Wrong section highlighted
    By ATLskate in forum M247 News & Support
    Last Post: 09-20-2003, 04:16 PM
  4. replacing quarter panel glass....
    By Dexter in forum Lounge
    Last Post: 09-03-2003, 06:11 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
