how to on lower grill removal
- remove the front bumper
- remove the grill
not too hard, just gotta fool around with it. i sent it to a shop and had the prongs and clips that hold the grill on for a cleaner look. gl
peace - chris
If you're not concerned with the grill, pull out on the grill at all four corners one at a time. Then look behind the grill and you'll see two vertical bars.. Pull the grill away from those bars.
Be careful and don't use too much force or things *will* break.
- remove the grill
peace - chris
no need to remove the bumper, the grill pulls off with a little force.
im thinking of having mine sanded down so you can see my FMIC better...i have the front grille off already and you can see it lol...
there are 4 clips, one on each corner, that you can remove by pinching them with some needlenose plyers. just make sure they don't pop back in...so pull while you pinch the clips. once all 4 of those are out, pull the grill away from the vertical strips with a bit of force and it should pop off.
i got, but i cant upload to the baord, idk y...
i cut of the bars n stuff
peace
- chris
