Page 2 of 8 FirstFirst 1234 ... LastLast
Results 16 to 30 of 106
Thread: How-To: Disabling Automatic A/C - Defrost modes
  1. #16
    xfimpg
    Guest
    Thanks to everyone who contributed to this solution!
    I just finished mine and am looking forward to the results.
    Mike
  2. #17
    Registered Member willy65000's Avatar
    Join Date
    May 2004
    Posts
    32
    Verry nice. Now if you could just tell me how to do that on My Mazda 3.
  3. #18
    goes to eleven chuyler1's Avatar
    NEMOC & Rotary Moderator
    2013 CX-9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,635
    Sorry to ressurect this but I wanted this done from the day I got my P5. I like to run the heat through the defrost-floor in the winter time because it keeps the dry air from blowing in my face (and making my eyes dry out). However, I also like to get good gas milage which won't happen if I'm running the A/C all winter long.
    Excellent post! This should be sticky if it isn't already.
  4. #19
    Thread Killer eting_pro5's Avatar
    '03 Pro5
    Join Date
    Aug 2003
    Location
    Novi, MI
    Posts
    1,010
    Woah woah woah....mega serious question.
    The ventilation system is always moving air through it, even when it's off. Additionally, although the blower is turned to 0, the temperature dial still has a noticable effect on the air coming out.
    Does this mean if I leave the controls on defrost and the blower to 0, is my AC still on??? If so, I think Mazda owes me a few grand in gas money....I've never gotten good gas mileage, but I always drive with the vent control on defrost.
  5. #20
    Registered Member Bumble G's Avatar
    Join Date
    Mar 2002
    Location
    Maple
    Posts
    97
    Quote Originally Posted by eting_pro5
    No your A/C is not on when the switch is at 0.
    The temp dial makes a difference because it's hooked up to a manual "door" that alows engine cooland to either come into the heater core or not. The air flowing in from outside always passes over the heater core. when you turn the dial to hot, hot coolant runs into the heater core, the outside air passes over the hot core and voila hot air with setting still at 0.
    Bumble G
  6. #21
    Registered Member Blown's Avatar
    Join Date
    Jan 2003
    Location
    Edmonton
    Posts
    289
    Would there be a built in software solution. I know on my 2001 civic, holding a couple buttons while turning the ignition on disabled it.
  7. #22
    Banned Dexter's Avatar
    Donated: $5.73
    Unauthorized DOUCHEBAG
    Join Date
    Sep 2002
    Posts
    11,960
    ^ Doubt it. I dont think the control board is that intelligent.
    eting_pro5: put it on recirculated air. this closes the fresh air door and you will not feel any more blowing. it feels like the fans are blowing when on "0" but when you are moving it just fresh air coming i.
  8. #23
    Experianced noob loccusst's Avatar
    2003 Yellow Mazda Protege5 Autostick
    Join Date
    Oct 2003
    Location
    Iowa...middle of nowhere
    Posts
    600
    I did this today while in the middle of working on my 95 contour (my winter beater). It took my all of about 20 min. to do, excellent right up and pics were definately the reason why it went quick. My contour also turns on the ac when you have the settings to defrost. Must be a Ford/Mazda thing.
    Anyone can drive fast in a straight line ...... Its driving fast around corners that takes skill.
  9. #24
    i've nothing to type here blynd_spy's Avatar
    2003 LX
    Join Date
    Aug 2004
    Location
    seattle, wa
    Posts
    513
    led out?
    does doing this mod cause the recirculating air led to not come on? i changed the leds at the same time, but the led isnt burnt and the circuit board looks fine..
  10. #25
    2003 LX
    Join Date
    Aug 2004
    Location
    seattle, wa
    Posts
    513
    nevermind, ifigured out my mistake.... the solder points for the led were touching...
  11. #26
    Registered Member
    Donated: $25
    Spicy Orange MSP #1287
    Join Date
    Mar 2003
    Location
    Sacramento/Galt, CA
    Posts
    2,404
    So, my main concern about this is whether this will actually help me save a little gas. Assuming that since the A/C is on, it wastes gas while I'm trying to de-fog my windows right? So, if I disconnect the A/C as shown, will I still be able to de-fog the windows without using the A/C??
    Current cars:
    2001 Acura 3.2CL Type-S
    1990 Honda Civic Si
    SOLD: Spicy Orange MSP #1287
    ENGINE - Injen Cold Air Intake//Ion Performance front-mount intercooler//GReddy Type-S blow off valve//JIC Magic 505-SUS catback exhaust system//Joe P. manual boost controller//Kartboy short shifter, bushings, shift knob//DG Motorsports carbon fiber engine cover//Perma-Cool oil filter relocation kit//Redline MT-90 synthetic transmission fluid
    WHEELS/TIRES/SUSPENSION - Tein SS coilovers//Fuzion ZR-i 215/45/17 tires//Rotor Works cross-drilled/slotted rotors//Axxis Metal Master pads
    INTERIOR -Tinted windows//Autometer full pillar triple gauge pod//Autometer oil pressure, boost, and air/fuel ratio gauges//Dave B. brushed aluminum gauge rings//Custom orange bezel
    IN CAR ELECTRONICS - GReddy full auto turbo timer//Viper Alarm//Airflow Logistics air/fuel controller//Sirius satellite radio//Kicker 12" sub
  12. #27
    2003 LX
    Join Date
    Aug 2004
    Location
    seattle, wa
    Posts
    513
    you can still use defrost with out the a/c... however, it will not defrost as fast since the a/c acts as a humidifier and for reasons i dont want to look up causes the window to de-fog faster.
    Im still getting used to it since ive only driven my car once since i did it so hopefully someone will jump in....
    hope that helps
  13. #28
    Registered Member
    Donated: $25
    Join Date
    Mar 2003
    Location
    Sacramento/Galt, CA
    Posts
    2,404
    As long as it works, that's all I need. I just hate using my A/C when defogging the windshield.
  14. #29
    Donated: $5.73
    Join Date
    Sep 2002
    Posts
    11,960
    Hey zap, got a question. you think that just closing the switch is sufficient enough to turn on the AC (as if i had pressed the A/C button on the console?)
  15. #30
    Electro-modder ZapWizard's Avatar
    Join Date
    Jan 2004
    Location
    Austin, TX
    Posts
    208
    Quote Originally Posted by Dexter
    I beleave so.
    There are two lever switches:
    One turns on the A/C
    The other activates the fresh air circuit.
    www.ZapWizard.com
    -Advanced Computer Modification-
Similar Threads
  1. A/C Compressor Cycling?
    By CentralPAZoom in forum Protege5
    Last Post: 08-23-2016, 01:05 PM
  2. The 'original' Quickest Road Car...?
    By AGR in forum Lounge
    Last Post: 08-08-2003, 12:10 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
