- ‘19 CX-5 GTR Tu
PLEASE MAKE THIS A STICKY or Locate to the How To!
I have seen lots of questions about how to make your own MIL/CEL Eliminator..
Well its really simple!
Tools Needed:
Wire Cutters
Soldering Iron
Solder
Electrical Tape
1-M Ohm Resistor ($1 at Radio Shack)
1-uF Capacitor($1 at Radio Shack)
Adjustable Wrench
Step1:
-Pop Open the Hood and get a look at the 2nd Oxygen Sensor
-There is a clip..Push the clip in and pull out the Male-Female Connection
-Using Adjustable Wrench Remove the Oxygen Sensor
Step2:
-Go somewhere you can use your Soldering Iron
-Cut the Blue Wire
-Remove the Sheathing on the White wire to expose the Copper Wiring Underneath
-Grab you 1m Ohm resistor and solder it into the bluewires you cut earlier
-Grap your 1uF capactiro and solder it into the wire that you unsheathed/exposed & than solder it on the connector side as show on the Pic!
-Grab your electrical tape and make sure you do a good job covering all the conections
Step3:
-Reinstall using the reverse directions in step 1!
Typical install time is 15-20min depending on your ability to solder!
Chas
Tools Needed:
Wire Cutters
Soldering Iron
Solder
Electrical Tape
Adjustable Wrench
Step1:
Step2:
-Cut the Blue Wire
Step3:
Chas
