CorkSport.com is MAZDA PERFORMANCE!
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Brake Booster
  1. #1
    ZOOM ZOOM BOOM BOOM CLUB mazdaspeed75's Avatar
    2003.5 mazdaspeed
    Join Date
    Nov 2003
    Location
    louisana
    Posts
    882
    Brake Booster
    Anyone use the vacum line off the brake booster for there bov If so can you just t into it Thanks
    Bossier city, la
  2. #2
    I <3 HKS KyRaceFan's Avatar
    03 MSP.
    Join Date
    Jul 2003
    Location
    Louisville, Ky
    Posts
    2,240
    Use the vac line from the stock BPV....
    your brake booster probably WONT ever see boost unless something is way wrong, so your BOV probably wont open correctly.
    2003 MSP #1130.
    Intake/MBC/EBC Greens.
    One of the 1st emanage MSP's till my diff exploded.
  3. #3
    2003.5 mazdaspeed
    Join Date
    Nov 2003
    Location
    louisana
    Posts
    882
    H
    Thats what i got my boost gauge on the bov is on the other line towards the back i thought you could put it on the brake booster line it goes into the motor my boost gauge flutters some i think because its on the same l;ine as the bpv Also i think if the bov gets a stronger source it will open better Not sure any info
  4. #4
    Registered User 03MSP's Avatar
    Donated: $5
    2003.5 Mazdaspeed Protege
    Join Date
    Oct 2003
    Location
    Omaha, NE
    Posts
    1,252
    A lot of people used the brake booster line...it's a good, strong source of vaccum...all vac lines see boost.
  5. #5
    03 MSP.
    Join Date
    Jul 2003
    Location
    Louisville, Ky
    Posts
    2,240
    Cool, good info, i was thinking the same thing about the vacuum lines all seeing boost, but since its the brake system, wasnt sure.
    Id also suggest looking on Joe P's website for the FPR install, and teeing in there for your boost gauge, and then using the original BPV tee for your BOV setup.
  6. #6
    Banned Dexter's Avatar
    Donated: $5.73
    Unauthorized DOUCHEBAG
    Join Date
    Sep 2002
    Posts
    11,961
    flyin protege tees into the brake booster also for thier kit
  7. #7
    Strongestmanintheworld Emode's Avatar
    Donated: 4.20$
    2k3bmMsp938
    Join Date
    Feb 2003
    Location
    Wisconsin
    Posts
    1,454
    i know this is back from the dead, but can someone please tell me the inside diameter of the brake booster line, and the stock BPV vacuum tubing, Im gonna run over to autozone and see if I can get a tee and run a dedicated line to the bpv and the wastegate. I searched but there is 300 threads about the stock BPV.
    thanks for any help
    Or if you have any suggestions, dems is good too
    MAZDA TEAM PWND BY LIFE
  8. #8
    '04 Mazdaspeed MX-5 #1089 jersey_emt's Avatar
    04 MSM #1089
    Join Date
    Aug 2003
    Location
    Center of infinity
    Posts
    9,370
    When you install the tee onto the line, you need to feel for a little bulge in the line. Make sure you place the tee to the left of that line (closer to the passenger side).
    That little bulge is a valve that prevents boost from passing through it...if you place the tee after it, your BOV will not work correctly.
    Not sure of the exact dimensions though...
  9. #9
    Donated: 4.20$
    2k3bmMsp938
    Join Date
    Feb 2003
    Location
    Wisconsin
    Posts
    1,454
    yeah I have searched all over and just cant find where anyone actually said what the diameters were. Im assuming the smaller vacuum lines to the bpv and wastegate are either 1/8 or 1/4 inch, and maybe the brake booster is one half inch, but im not sure.
    anyone?
  10. #10
    Donated: 4.20$
    2k3bmMsp938
    Join Date
    Feb 2003
    Location
    Wisconsin
    Posts
    1,454
    ok went out and measured a bit
    regular vac hose to bpv, etc is 3/16 inch inside diameter
    called flyin protege about brake booster line, they thought it was either 3/8 or 5/16, but no definitive answer.
    argh.
  11. #11
    03 MSP.
    Join Date
    Jul 2003
    Location
    Louisville, Ky
    Posts
    2,240
    i finally got around to using my brake booster line tap for my BOV, and swapping the FCD to the same T as where the stock BPV draws vacuum.
    I maybe noticed a tiny change in the BOV sound. but probably not
    I also moved the boost gauge to the Fuel Pressure line. Shows a little more vacuum, and the boost gauge is a little more jumpy as it builds boost.
    Ohh well, its all good.
  12. #12
    Breathe 505zoom's Avatar
    2003 MSP #119
    Join Date
    May 2003
    Location
    Albuquerque, NM
    Posts
    4,521
    Quote Originally Posted by Emode
    ...Im gonna run over to autozone and see if I can get a tee and run a dedicated line to the bpv and the wastegate. I searched but there is 300 threads about the stock BPV.
    thanks for any help...
    Part # 47354 at autozone. It is an assortment, and you use the largest one.
    - Rich's stock block 277whp MSP -
    - 505 Autosports - AEM - A'PEXi - Blitz - Boost Sciences - Clifford - CR3 - Dave B - Delsing - DGM - Eclipse - Espelir - Flyin' Miata -
    - Frozenboost - Garrett - Hella - J&S - JayRacing - JL Audio - JSP - Kartboy - LeadFoot - Lightning Audio - Magnaflow - MBQuart -
    - Mental Addiction - PWR - Redline - SPAL - Sparco - Spearco - SPEC - Stewart Warner - Tokico - Xcelerated Concepts - Xtant -
  13. #13
    2003 MSP #119
    Join Date
    May 2003
    Location
    Albuquerque, NM
    Posts
    4,521
    Post #8 on this thread has a pic of the package:
    /forum/showthread.php?t=53776
  14. #14
    Donated: 4.20$
    2k3bmMsp938
    Join Date
    Feb 2003
    Location
    Wisconsin
    Posts
    1,454
    thats funny, i just walked in the door, and I picked up that exact package from autozone, also got a ton of red silicon hose and some zip ties, ill let people know how it goes.
  15. #15
    Donated: 4.20$
    2k3bmMsp938
    Join Date
    Feb 2003
    Location
    Wisconsin
    Posts
    1,454
    is there an easy way to get at the wastgate hose connection point, without taking off the intercooler piping and stuff? I am having a hard time getting down there.
Similar Threads
  1. Is wilwood still only big brake kit?
    By p5sundevil in forum Mazda Protege
    Last Post: 06-09-2004, 11:00 PM
  2. Thoughts on the MSP euro-spec brake pads
    By MikeyG_U2 in forum Mazdaspeed Protege
    Last Post: 01-16-2004, 04:29 PM
  3. hand brake light problem
    By mopiko in forum Protege5
    Last Post: 01-13-2004, 05:11 PM
  4. About the brake sound!!!! please help!!!
    By markleung in forum Protege5
    Last Post: 10-31-2003, 02:15 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
