LOL, yeah, well I start my tuning at WOT and work my way back.igdrasil said:Looks ok for a race track!
But if i AM knocking, I can't hear it.Little Beavis said:Dude, that ignition map is all kinds of wrong!
Edit: To be a little more helpful.
You should either be using the AMP column and pulling timing based upon boost (via the MAP you are using), or you should be pulling timing in all areas (where boost is made) rather than just WOT. As it stands you are probably knocking if you run anything other than WOT, because you'll be building boost without pulling timing.
I know one thing to always be true. If you hear knock it is worse then you think.Kooldino said:But if i AM knocking, I can't hear it.
Also, when I had the exact same numbers in my AMP column, it would go funky on me and knock. ???
MPNick said:I know one thing to always be true. If you hear knock it is worse then you think.
Thanks again
Later..........Nick
Yes, that would be right, but I never get up to the top of the AMP column. So, I don't have that much retard dialed in. In fact, I'm probalby not at full boost in the lower midrange so that would mean I'm maybe at -7 or so. But your number wouldn't be that bad, except the MP3 has advanced timing, so you're actually pulling more than I am even if you give yourself an extra degree per psi to get to 13. However, no one seems to know how much more timing the MP3 has.Kooldino said:Cool. I've been trying to get my hands on it all day.
So jeremy - your max retard is -9*...is that on the MP3 ECU?
My current max retard is -12 or so @ 13psi. Sounds about right.
