A quick note on the reoccuring comments regarding turbochargers and warranty denials. As per legislation passed in the late 70's, the Magnusson-Moss Act prevents manufacturers like Mazda from denying warranty claims from folks like us.
In more precise terms, the act says that a manufacturers cannot deny a warranty claim from a consumer on grounds of modification to the vehicle. Mazda cannot simply deny a warranty claim beacuse you have an intake, exhaust or a turbo for that matter. They have to prove in writing that the modification had a direct cause and effect relationship on the part that failed.
For instance, lets say you have a 2002 P5 turbocharged and intercooled. You go out for a drive one afternoon and notice that the A/C has gone out. Barring any tampering to the A/C system during install the car and part can be claimed under the manufacturers warranty turbocharged or not. On the other hand, if you go in becuase you put a rod through the block after pushing 14lbs of boost it would be reasonable for them to make a case against you.
Don't let the dealerships beat you up!
Mike
Mike
