Okay.....After dealing with the dreaded 'clunk' problem due to subpar, unlubed rubber bushings on the rear sway bar, I have found a permanent fix, that actually increases the performance even more. I decided to replace the rubber bushings with Energy Suspension Polyurethane bushings. I purchased item # (9-5157 13/16") from http://www.nipponpower.com. The guys there were very helpful with getting me this part. I took me about an hour to replace the self greasable bushings. It was pretty simple, but did require some modifications. First off, the original bushing bracket is shaped differently from the new one, so I had to shape the new bracket with a hammer, very simple. Second obstacle was a bushing stoppage piece on the sway bar that prevents the bushing from slipping back and forth on the bar. These need to be pushed toward the inside about a quarter of an inch on each side. Other than that, you just grease up the bushings with all purpose grease and slip them on, bolt up the brackets and reap the benefits of Poly bushings! Maybe just me, but I think it stiffins cornering. NO NOISE AT ALL!! And the best thing about them, is that theyre self greasable. Has a nipple on it so that you hook a grease gun to it and pump in lube! I took pictures at several stages throughout the modification and I am currently working a tutorial....soon to come.
Dimensions in image are not actual to dimensions of part number 9-5157
