Dexter, you shouldn't need any special adhesives for the rear quarter windows on the sedans. The P5's require it though. All you need to do is remove the door panel from the door. Carefully peel back the vapor barrier. Roll the main window down enough to access the screws holding it to the window regulator. Remove the screws and carefully lift out the glass. Then, unbolt the glass guide. There is a bolt on the top of the door frame and a bolt on the sheet metal portion of the door shell.
Next work the glass guide out of the window frame. Pull out the weatherstripping for the quarter window. It should just pop out. If the stipping is damaged, you should replace it so it won't leak. Install the weatherstripping around the new quarter window glass and reinstall everything.
Good Luck! It's really not too bad...I've replaced a few myself, and one was in a buddy's LX.
