15in Steel Fit p5 Correct?
Joe PR5
someone is selling 15in steel rims that i want to use for the winter, they fit the p5? anyone use them last winter? there 5x114 mm bolt pattern which I believe is correct as well.. Thanks..!
Yea.. But i wanted to know if they will fit my p5.. Im like 90% sure i have seen p5 with 15in steel rims.. and thats the same bolt pattern, so i dont know why it would not fit.,??
If they fit on the MP3, then they fit on the P5.
5x114.3 is, indeed, the bolt pattern. If they arent' off an MP3, just check the hub bore to make sure it's right (I can't remember what the bore is on the P5). Backspacing shouldn't be an issue.
grishulia--- If you want to pay $250, there all yours.. Your just here to make my life hard huh???????(guns)(laugh)
Nah im joking, if you have that kinda flow for those wheels, more power to you.. good luck,,
