what fuse does the cig lighter run off of?
The fuse panel inside the car. If you look on the cover you take off there's a chart showing what goes to what.
well
if its the same chart that is in the owners book, it doesnt say!! there are a few fuses for interior stuff but they all checked ok!!
did you check the "room" fuse? also it may be a wire problem in the connections in the back of the cig lighter. I think someone else had that problem a while ago. Have the dealership look at it if its not as simple as a fuse problem unless you want to dig in your dash for the problem.
