Hello All,
I have a problem w/ my P5 and need to take it to the dealer. I am almost positive they will give me a B.S. answer when I take it to them. Here is my issue.
When I start my car the Idle jumps up to somewhere between 2500-3000 RPMS. When I first got the car it would idle around 1000. No big deal.
Now the high idle stays for like 5 minutes, even when driving. It is so bad I do not even need to press the gas pedal when releasing the clutch from a stop to forward motion in 1st gear and with no gas pedal I am still cruising at 10 miles an hour.
I know there is supposed to be some type of temperature sensor that will make the car run at a higher idle when it is cold out to make the engine warm up faster. That I could live with but this happens when it is 85-90 degrees out.
Once I run the car the idling issue seems to go away but comes right back the next morning or afternoon, depending on when I go somewhere. I have checked the throttle cable so it is not sticking and made sure the idle adjustment is set correctly. I am at a loss.
Someone told me I may have a bad IAC motor that could be causing my problem. What sucks is I have to leave my car at the dealer's overnight so they can here and see what I am talking about in the morning when they start it.
If you all could provide any insight or if this has happened to anyone else, please let me know.
p.s. I thought this may have been mentioned before but I could not find it in the search. If already discussed. Please forgive me. Thanks, everyone.
