$500 to spend on system?
Help Pick A System Selection Please!
do you guys think it would be possible to get a system for $500, deck, subs, and amp???
anybody got any suggestions on what i would be able to get???
i was thinking about getting 3 - 10"in mtx and then later get another 3 - 10"in mtx...
anybody got a good setup for that price range???
With $500 buy a decent deck and some JL VR's off E-bay...unless you want a Rampage system. Go with a Mid level Pioneer or Alpine deck...$200 Pioneer 6400 Deck and $300 (2) pairs of JL VR's...then save some more cash and put a sub in. The wiring for a sub alone would cost about $75 (power and RCA's)...are you going to install yourself???
yup installing myself....
made a list of what i was looking at so far if anybody thats good with the audios help a brother out and let me know any suggestions on any of my selections???
2002 PYLE GEAR 12"
SUBWOOFER 2000W PAIR
BRAND NEW IN FACTORY SEALED CARTONS
12" WOOFER
4 OHMS IMPEDANCE
2000 WATTS POWER HANDLING PAIR (1000 WATTS EACH)
2" VOICE COIL
KAPTON 4 LAYER VOICE COIL
SENSITIVITY 93DB
FREQUENCY RESPONSE: 38HZ-4.2kHz
90 OZ. MAGNET STRUCTURE
4.5" MOUNTING DEPTH
ROCKWOOD USA
12" COMPETITION SUBWOOFER
1000 WATTS PER SUB 2000 WATTS TOTAL PER PAIR
DOUBLE DAMPER, DOUBLE MAGNET
DUAL TERMINAL 2, 4 & 8 OHM OPERATION
DUAL VOICE COIL
GOLD-PLATED SCREW TYPE TERMINALS
DUAL VOICE COIL COOLING SYSTEM: BUILT-IN BASKET AIR VENTILATION, FRONT VOICE COIL COOLING VENT SYSTEM
HEAVY STOCK NON-PRESSED COATED PAPER CONE WITH HEAVY DUTY JUMBO SURROUND
DUAL DAMPER
160oz. DOUBLE STACKED MAGNET!!
INDUSTRIAL BOLT CONSTRUCTION
AUDIOBAHN WOOFERS
AW-1251X
(2) 12 1400 WATTS (TOTAL)
NATURAL SOUND SUBWOOFERS
BRAND NEW IN FACTORY SEALED CARTONS!
PAIR OF WOOFERS!
NEW FOR 2002
PYRAMID IMPERIAL 12290
INSANE 2400 WATTS TOTAL
SUBWOOFER PAIR
YOU GET 2 OF THESE FOR $98.00! INSANE DEAL!
NEW 2002 MODEL WITH SUPER PHAT SURROUND
GOLDEN INJECTED POLYPROPYLENE CONE
WIDE NON-FATIGUING RUBBER SUSPENSION
RUBATEX GASKET
GOLDEN-PLATED STEEL BASKET WITH GOLD TERMINALS
GOLDEN-PLATED BACKPLATE WITH BUMPED AND VENTED STRUCTURE
2.5" HIGH TEMPERATURE KAPTON VOICE COIL (4-LAYER)
4 OHMS IMPEDANCE
60 Oz+ 60 Oz MAGNET STRUCTURE
2400 WATTS PEAK POWER FOR THE PAIR AND 1200 WATTS PEAK EACH SUBWOOFER.
IMPEDANCE = 4 OHMS
Fs (Hz) 27.6
Qms 6.5
Qes 0.63
Qts 0.57
SPL (dB) 85.8
Vas (cu ft) 2.652
Mounting Depth 6.10"
Overall Depth 6.69"
Mounting Diameter 11.02"
Overall Diameter 12.20"
AMERICAN PRO
15" All-Chrome Woofer: 800 Watts Max; 400 Watts RMS; 4 Ohm Impedance; Rubber Surround; Kaptan Voice Coil; Screw Style Terminals
COMPETITION READY SUBWOOFERS
TWO - 15" SUBWOOFERS PYRAMID PW1586
15" SUB WOOFER
1200 WATTS PEAK POWER EACH
GOLD PUSH TERMINALS
POLY CONCAVE DUST CAP
PYRAMID HYPER PRO SERIES FEATURES
HIGH PERFORMANCE PAPER CONE FOR FAST ATTACK
WIDE HEAVY FOAM SURROUND
RIGID POWDER COATED STAMPED STEEL BASKET
BUMPED AND VENTED POLE PIECE
HUGE 110 OZ MAGNET STRUCTURE
OVER SIZED 2.5" KAPTON VOICE COIL
4 OHM IMPEDANCE
SINGLE VOICE COIL
FS=36.8HZ
QMS=7.17,QES=.1.7,QTS=1.37
SPL=86
VAS=3.111
Mounting Depth: 6.06"
these are the amps i have in mind
PYLE
2 Channel 1400 Watt High Power
PLA1440 MOSFET Amplifier
Specifications:
- DUAL 5 LED METERS
- HIGH-LOW ELECTRONIC CROSSOVERS
- VARIABLE BASS BOOST & GAIN CONTROL
- REMOTE TURN ON/OFF
- MOSFET PWM POWER SUPPLY
- SOFT TURN-ON CIRCUIT
- HIGH & LOW LEVEL INPUTS
- HIGH LEVEL MOLEX INPUTS
- GOLD PLATED RCA INPUT JACKS
- POWER ON & PROTECTION LEDS
- S/N RATIO: 90DB
- FREQUENCY RESPONSE: 20HZ-30KHZ
AMERICAN PRO BASS MACHINE
2000 WATT MOSFET POWER
2-CH BRIDGEABLE POWER AMPLIFIER
FULL MOSFET POWER SUPPLY
2 OHM STABLE
2-CH BRIDGEABLE
24dB BUILT-IN CROSSOVER
MAX OUTPUT POWER 2000 WATTS
VARIABLE GAIN CONTROL
DUAL FAN COOLING SYSTEM
AWESOME REAL CHROME
VARIABLE LPF CROSSOVER (30Hz-300Hz)
LOW/HIGH LEVEL INPUT
TRI-SPEAKER HOOKUP
GOLD PLATED RCA AND TERMINALS
HUGE 100 AMP MAXI FUSE BUILT IN
OVERHEAT AND OVERLOAD PROTECTION
POWER/PROTECTION L.E.D. INDICATOR
FULL 2-YEAR WARRANTY
DIMENSIONS: 10"(W)x22"(L)x2.5"(H)
AMERICAN LEGACY
HIGH PERFORMANCE
2000 WATT 2-CH
MOSFET AMPLIFIER
TWO CHANNEL AMPLIFICATION
1000 WATTS x 2 OUTPUT
2000 WATTS x 1 BRIDGED OUTPUT
FULLY ADJUSTABLE ELECTRONIC CROSSOVER NETWORK
VARIABLE BASS BOOST (0-12dB @60Hz)
SOFT TURN ON/OFF CIRCUIT
2 OHM STEREO STABLE
BRIDGEABLE INTO 4 OHMS
HEAVY DUTY ALUMINUM ALLOY HEATSINK
DISCREAT WIRE CONNECTIONS
REMOTE TURN ON/OFF
HI/LO INPUTS
GOLD PLATED HIGH IMPEDANCE INPUT
HIGH LEVEL MOLEX OUTPUT
POWER ON LED INDICATOR
LED PROTECTION INDICATOR
S/N RATIO: >95dB
FREQUENCY RESPONSE: 15-30kHZ
AMERICAN LEGACY
HIGH PERFORMANCE
2000 WATT 2-CH
MOSFET AMPLIFIER
2 OHM STEREO STABLE
REMOTE TURN ON/OFF
HI/LO INPUTS
S/N RATIO: >95dB
NEW 2003 LEGACY SERIES 2 LINE!
2400 WATT 2-CH LEGACY AMP
2 Channel Amplification
2 x 1200 Watts Output
1 x 2400 Watts Bridged Output
2400 Watts Total Output
Polished Chrome Finish w//Plexiglass Panel
Remote Control Bass Boost (0-+1808 @60Hz)
Fully Adjustable Electronic X-over Network
Soft Turn On//Off Circuit
2 Ohm Stereo Stable Bridgeable Into 4 Ohms
MOSFET PWM Power Supplies
Variable Gain Control
Hi//Low Level Inputs
Power On LED Indicator
LED Protection Indicator
if someone is bored and they wanna pick the best setup out of my selection feel free......
also should i be getting a bandpass box or a regular box???
I'll sell you my two 12" kicker solo-barics with a 600a4 rockford fosgate amp(1000 watts bridged), a 1-farad fosgate capasitor and all the 4-gauge. It'll blow the hatch open!
Damn near everything you listed is complete GARBAGE!
With only $500 total your going to need to keep the factory deck which is actualy a good thing since its a better signal quality unit then decks going for even $400.
The amp will be around $200 to get enough real power to push to decent 12"s. The Kicker 200.2 is a good choice.
Any 12" sub under $100 retail is junk, plain and simple.
If you want a good 12" then get the JL12W0. If you want volume and don't give a damn about SQ get kicker comps.
A decent box for 2 12" subs will cost abut $100 to make at a reputable shop.
If it were me and I had $500 I would get a 4 channel amp and 1 sub. Use the 4 channel amp to power the front speakers and one sub. Then later bridge the 4 channel to run the front speakers, once I bought better ones, and add a seperate sub amp and another sub.
budget is at $500 and want something with some thump to it. wanna be the man with all the power in the hood. my brother just got 2 15" rockfords with a 1600 watt amp.. want something to at least match him or pound him...
Nothing for that little cash, tripple it and maybe you can do somehting.
rockwood? are those fosgate knock offs? boO
as far as boom boom.. i just got my polk exs used from a friend $100 for both in a box.. not the best but hey it works.. buut if i was u.. instead of buying a bunch of junk to go boom boom pop.. id buy one nice thing at a time.. slow progression is true beauty. -=)
Its also all about the install.
I know people with Great equipment, but do not sound all that great with a crappy install.
On the other hand, i know people with decent equipment and a great install that will knock your socks off.
you could pick up that crap at a warehouse sale for like $5. Don't even bother. It prolly sounds worse than stock.
Go with one strong 12" sub and a 200 watt amp. Run the amp bridged parallel. To the one sub. It will ROCK for $500. Go JL sub and pick an amp. You will bump plenty hard enough. Make sure your amp has a built crossover of some type.
Rockwood, Kingwood, Pyramid and all that garbage I have seen at flea markets...bunch of junk IMHO. For $300 il sell you my Orion 500.5 5 channel amp and audiobahn 10"subwoofer.
if you are really looking for a system that is going to blow all your buddies off the street.....take your $500 and put it in the bank and start saving your money.....then come back and start looking for options when you have about $1500 to spend on your system.
I for one would hate to see you go out and spend $500 hard earned bucks only to be disappointed with the system you got...and have your buddies tell you how bad it sounds...or worse yet....tell you it was crap. Nothing worse than to have spent your hard earned money, only to be dogged buy your buds about what you got for it.
What do you REALLY want out of your system? do you ONLY want killer base that will rattle your car ? or are you wanting a well rounded system that will give you some of everything....highs, mids, and lows?
one thing you can do to ensure you are fully satisfied with the end result....do NOT buy cheep equipment....buy quality...sure it will cost more....but you will be a lot happier with the result.
I upgraded my system a while back....kept the stock headunit, added a 5 channel Alpine amp that is ONLY 40 watts/channel RMS, AND 125 watts RMS to the sub, upgraded all the door speakers (used rockford fosgates all around) and added a single 10" sub in the back (a JL Audio 10W0 Powerwedge) and with the wiring kit....the total came to just shy of $700.....and I did all the install.....
so you see.....$500 isn't going to get you far in the BIG THUMPIN world of sound.
(stash)
I have 2 12" jl audio subs and a mtx thunder 8302 amp. You think my stock alternator will hold up. I have a 02 protege5
Latest posts
