LAst years sub box so don't pay retail for it. The new one looks great. The 250/1 is a great sub amp. Its costly but I have no doubt that it can crank more then 300 watts rms out. Also it has some of the best crossovers on the market and unlike other amps when it hits hard it doesn't loose power do to voltage drops. Also if you decide on a 2 ohm setup of subs in the future that amp is still going to give you all of its power.
As 1st MP3 will tell you, JL Audio is sold NOWHERE online under warranty. To get JL Audio with a warranty and everything, you will need to go to a shop nearby. I know www.onlinecarstereo.com sells JL products, but no PowerWedge and no warranty. You really need a shop.
Another thing to add and I know if your saesmen told you but since tweeter has it own authorized repair center, owned and operated by tweeter for tweeter stores, If you have to send something in for repair we attach a little sticker to it that tells the reapair center you have our warrenty and your repair gets bumped to the front of the line over those without that sticker.
yeah, i deal with the same salesman every time. hes a cool guy and he gives it to me straight, rather than dicking me around. in fact i was looking at a different amp and sub and he helped me choose mine. i am very happy with it and i appreciate his help.
You can get the discontinued model for that. For no warrenty on the box or sub why bother saving $20. The brands ass new single 10W0 in a JL box is only $169
Sir Nuke, Thanks for the info from my other post... So that velcro secures the Alpine well, huh? Sounds like the way to go without drilling through the carpet.
I plan on doing the install myself. Gotta start sometime...
How do I take off the front panel to work on the stock HU?
The alpine amp has speaker level inputs. You cut the speaker wires behind then run the radio side of the wires to the speaker level input of the amp. Then run the amps output wires back to the factory wires that are still cut and behind the radio that go to the speakers.
