- Plano, Texas, USA
That’s for 2015 CX-5 and prior ⋯80w90 is in the manua too
For 2016 CX-5 and up, use Mazda Long Life Hypoid Gear Oil SG1.not for the 16 and up models.
please correct me if im wrong,thats what my manual says.
⋯ EXAMPLE DIFF. BETWEEN 2013 AND 2016 YMs
Do you have Mazda dealers in your country?yes,no where to be found in israel and its illegal to ship from over seas.
is there an equivalent to the the sg1?any gl5 oil will work?
Then why can Mazda simply design a proper location of fill hole at the first place so that it reflects the gear oil quantity they designed for like everybody else? The front casing of rear differential had been redesigned at least once to resolve premature wear on input shaft bearing, why can Mazda relocate the fill hole at the same time to eliminate the confusion? A penny saved is a penny earned. If each car saved $2 on gear oil, it’d save $300K per year just from US CX-5 sales!Has anybody considered that the minimum required amount of oil is less than the refill procedure indicates, and that the refill procedure is written to make it easier. At the factory they may have better and more controlled ability to fill and measure a precise amount. I think it unlikely that Mazda is so cheap and/or incompetent to try and save, or fail to fill $1.50 worth of fluid for more than a short run before making a correction at the factory. The fact that the alleged under-filling spans multiple model years makes me think it, if real, intentional. Mazda must have a reason for filling to where they do, and I suspect its a good one. Not saving a dollar or two per car.
I guess my argument is still, why does Mazda implement the same way like you described at front transfer case to save another $2?Assume a hypothetical, that a case performs and lasts equally well if the total enclosed volume is anywhere from 30% to 70% full with oil.
It would make sense for Mazda to put the user refill line at 50% full to allow maximum margin for error for what the aftermarket mechanics may do in the say 30% of cars that ever have the fluid checked or serviced.
But at the factory, Mazda would likely only fill to 35% full because they may have a +/- 1% variation in their fill and measurement process. In this case, it makes sense to save the $2 if there is no functional downside to using less than the 50% they put in the user fill process.
In this scenario, amateurs checking or trying to remedy the fill much earlier than the service interval are more likely to do harm than good.
I'm just making up these numbers. But a scenario like this seems far more plausible than Mazda intentionally, or through negligence, continuously failing to put an adequate amount of oil in their new cars.
edit: of course another plausible explanation could be if the lower fill allows them to pass some test or criteria for the new cars that is necessary or desirable for them. Such as meeting fuel economy targets.
I'm assuming most of their designs are evolutionary, where they borrow design intent, and in many cases direct CAD from previous or parallel efforts. In many cases decisions on what to ship may be based on existing tooling or copy and paste design elements. If it works and meets function, you don't change your tooling or design set just so some small percentage of end-use mechanics can see the consistency.I guess my argument is still, why does Mazda implement the same way like you described at front transfer case to save another $2?
Yes, who knows why Mazda did this way. But one thing for sure is they did this and other things which I don’t agree with are for cost savings.Who knows. Whatever the reason, I'm sure it made sense to Mazda considering their design philosophy, and standing as most reliable car brand, think it unlikely that the reason is incompetence or negligence.
Yeah I wouldn’t mix SG-1 with any other gear lubricants. And based on Mazda specs, the gear oil capacity for front transfer case on gen-2 CX-5 is 0.48 quarts and rear differential is 0.37 quarts. But in reality by following official Mazda refill instruction you need about 0.48 quarts for the front and 0.8 quarts for the rear. And you do need to get 2 quarts of SG-1, not 1, for both front and rear gear oil replacement.never mind probably not,bought another one for 83$
never had problem with spending good money on taking the best care for my cars its just a shame i new that before i could save 45$on the shiping.
