Results 1 to 3 of 3
Thread: Clunk/pop in drivers front wheel
  1. #1
    Registered Member
    Join Date
    Dec 2019
    Posts
    1
    Hi all: 105k on my 2013 Cx-5. Hearing a clunk or pop when going over dips in the road or when the drivers front has to flex when pulling into driveways and what not. I replaced both front end links as well as complete quick struts (strut, coil, mount etc). Anything else it could be?
  2. #2
    2008.5 MGM MS3 rsvinylgraphics's Avatar
    Donated: $5
    Join Date
    Oct 2009
    Location
    Indiana
    Posts
    1,200
    ball joint maybe? with the wheel off the ground grab the top and bottom of the tire and try to move it back and forth if it moves and clunks thats probably the problem.
  3. #3
    Registered Member
    2019 CX-5 Grand Touring Reserve
    Join Date
    Apr 2019
    Location
    California
    Posts
    29
    I had a similar thing in my 2019. Although I am not sure if it is exactly the same, then I went over bumps (intermittantly) there was a clunk noise.
    I took it in and there were some loose bolts on the cross bar in the engine (closer to the windshield).
    Maybe give everything a quick knock to make sure you dont have anything loose?
Similar Threads
  1. Replies: 5
    Last Post: 04-14-2013, 07:59 PM
  2. Popping from front Drivers wheel
    By wannabe in forum Mazdaspeed6
    Last Post: 06-14-2011, 05:18 PM
  3. Drivers side clunk...
    By 08SPEED3Veteran in forum Mazdaspeed3
    Last Post: 08-31-2009, 05:20 AM
  4. Wheel well clunk
    By comixx in forum Mazdaspeed3
    Last Post: 01-24-2008, 10:49 PM
  5. Wheel hop or clunk?
    By BlueBeast22 in forum Mazdaspeed Protege
    Last Post: 03-06-2006, 03:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
