Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Battery life?
  1. #1
    Registered Member
    2016 CX5 GT
    Join Date
    Mar 2018
    Location
    PA
    Posts
    70
    Battery life?
    I have a 2016 CX-5 and today it wouldnít start. Now I did fully wash it and clean the interior, so the doors were open for some time, but really not for an enormous amount of time. I did not have accessories on or the radio. I cleaned all the seats and vacuum it out really good.
    Then 2 hours later I go to start it, all electronics come on, including a confusing state of turn signals and wipers (from wiping those stalks earlier), but the car wouldnít complet turning over. When my wife got home from work I was able to jump start it. I let it idle for an hour and then I was able to shut it off and start it.
    When it wouldnít turn over, multimeter read 12.08 volts at the terminals. When it was idling, it read almost 13 volts. Now shut off it reads 12.68 volts.
    The car is only 2016 model year, and now itís 2019- so really is the battery that bad? Iíve never had cars where the battery didnít last at least twice that (6 years or even more).
    Whatís a good battery to get? Is Die Hard a good one? What about Duralast. I just want it to last and work especially with winter coming up. It was 52 degrees today but it will get cold before you know it.
  2. #2
    2008.5 MGM MS3 rsvinylgraphics's Avatar
    Donated: $5
    Join Date
    Oct 2009
    Location
    Indiana
    Posts
    1,200
    Car batteries these days seem to only last about 3-4 years. You may be showing good voltage but amperage is also important. Autozone can load test the battery (free) to see what amperage you are at.
    Most people here have been getting their replacement batteries at Costco for around $80 or so.
  3. #3
    Registered Member
    2019 CX-5 GTR
    Join Date
    Jul 2007
    Location
    North Carolina
    Posts
    101
    Yes a load test like they do at the parts store is the only way to know the battery health. There are a lot of factors in battery life and 3 years might be in the range. I usually look for a sale on a AGM style battery to replace.
  4. #4
    Registered Member
    Mazda CX 5 Touring
    Join Date
    Feb 2016
    Location
    Jacksonville
    Posts
    35
    Since you know what the voltage on the battery is I assume you have a meter. Hook it up to the battery and have someone turn it over while you read it. If it drops below 10 volts replace the battery.
  5. #5
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,430
    Arrow Battery life?
    Quote Originally Posted by Kjstech View Post
    Your battery most likely is 4+ years old as Mazda started selling 2016 CX-5 on February, 2015. I believe your battery definitely is weak and your may need a new battery. Take the battery to an auto parts store and have it load-tested like others have said as the voltage can't tell you too much about the true cold cranking amps (CCA) from your battery. I wouldn't get the Die-Hard battery (I thought Sears is gone?), but get an Interstate Group 35 battery from Costco for $79.95 which is the best value you can find. The bad part is you have to install the battery by yourself, and bring the old battery back for core charge with a second trip to Costco.
    Next time when you're cleaning up the interior, turn off the dome lights with interior light switch on the ceiling to save some electricity from battery.
  6. #6
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    585
    If your battery drained in an hour or two from the interior lights, I would get a new battery. There is nothing worse than being stranded some where with a dead battery. If you get it load tested and it checks okay, I would in the least get a lipo jump pack so you have a way to jump it in an emergency.
  7. #7
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    435
    Your battery lasted longer than the one on my 2013, lol. My Corolla I donít have anymore? Not even 2 years before it failed.
  8. #8
    Registered Member
    2014 mazda cx-5 touring FWD
    Join Date
    Dec 2015
    Location
    midwest
    Posts
    155
    I just replaced my battery a couple of weeks ago even though it was still "good" and started the car.The dealer checked the battery as part of an oil change inspection 2 days prior and it had lost some capacity compared to the previous inspection/oil change.But I was noticing it cranking over slow on cold days (about 35*F) and it being over 6 years old (car built 9/2013) was not feeling it would perform well at 0* or below.The new battery is rated at about 550 CCA which is well above the original and it spins over quick.It's a group 35 size that fits right in.You know darn well that when your old battery fails it's not on a sunny 70* day in the parking lot of an auto parts store.Funny thing , it was drizzling when I went in the auto parts store but turned to snow flurries when I came out.Good timing.
  9. #9
    Registered Member
    2016 CX5 GT
    Join Date
    Mar 2018
    Location
    PA
    Posts
    70
    The dealer did an oil change, front brakes and brake fluid flush last Monday. On the paperwork it said ďgoodĒ for that battery.
    Iíll look into the cosco route. Do you have to be a member? Isnít that like Samís Club?
    I had a Bosch battery last 8 years in a VW I had. Now that car didnít have a full color LCD stereo system with Apple CarPlay and all that.... but it was still an impressive length of time for a battery to last. The indication to change that battery was randomly losing radio presets and the clock resetting to 12:00. I got that changed out before it left me sit.
    I think my wifeís previous car, a Ford Escape lasted about 7 or 8 years as well (a motor craft battery). It was a 2003 car and we moved into the house we are at now in 2010. I seem to remember it was shortly after that in the early winter of 2010 or 2011. We privately sold that car a few years ago so but at the time of the sale, the Duralast replacement was still going strong.
  10. #10
    Registered Member ceric's Avatar
    2017 Mazda CX-5 GT, 2016 Mazda6 iGT, 2014 Mazda3 sGT hatchback
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    4,480
    '14 Mazda3: lasted 3 yrs
    '16 Mazda6: lasted 3 yrs
    '17 Mazda CX5: still original one.... closely watching it
    2016 Mazda6 iGT + Tech Pkg
    ....Sonic Silver Mica / Parchment
    ....Soul Red Metallic / Almond
  11. #11
    Registered Member
    Join Date
    Apr 2012
    Location
    Canada
    Posts
    191
    My CX-5 went into service August '12. I'm still using the original battery here in cold Ottawa.
    Brian
  12. #12
    Registered Member
    Join Date
    Oct 2012
    Location
    FL
    Posts
    435
    Quote Originally Posted by bamirault View Post
    Brian
    Thatís awesome. Is it a battery you have to add water to? Mine was. Iím thinking FL heat killed mine.
  13. #13
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,939
    Put a charger on the battery to fully charge it and get it load tested. ed
  14. #14
    Registered Member
    Cx-5 Sport
    Join Date
    Nov 2019
    Posts
    29
    My 16.5 cx5 battery wouldnt start. I took it to abattery place and they said it was ok. It just needed a thorough trickle charge. Its been fine since then but I am trying to trickle charge every couple of months.
    I back it into my garage sometimes so I can clean it or prepare for camping and that can deplete the battery.
    The running voltage at 13.8 is a bit lower than the voltage in my Chevy. Maybe that is just Mazda policy. My oem battery in my 86 626 lasted 7 years. They use good batteries.
  15. #15
    Registered Member
    Join Date
    Apr 2012
    Location
    Canada
    Posts
    191
    I certainly hope that it is maintenance-free, 'cause I haven't done anything with it since new. Only tangentially related, I am booked to have it replaced by the dealer December 19 on speculation. They claim it's fine, but that day I am scheduled to start a 7-day drive to Tucson. It certainly doesn't owe me anything and I would rather not have it fail part way to my destination.
Similar Threads
  1. key fob battery life
    By PhillyMike in forum CX-9 General
    Last Post: 11-30-2018, 04:19 PM
  2. key fob battery life?
    By ZzRicezZ in forum CX-9 General
    Last Post: 11-17-2017, 05:29 PM
  3. Battery life for 2015 CX-5
    By calebian21 in forum CX-5 General
    Last Post: 10-13-2017, 04:23 PM
  4. Battery life
    By erhayes in forum CX-5 Engine & Transmission
    Last Post: 12-27-2016, 11:48 AM
  5. Key fob battery life?
    By SmurfaceWarfare in forum CX-5 General
    Last Post: 04-11-2015, 09:55 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
