2010 rear caliper parking brakw cable removal (help).
davecrash
Mazda 5
I was doing the brakes today, all the pads were at about 50% so it was just suppose to be a clean and grease job. the last one was down to almost no pad, the caliper piston boot was damaged and i assume the corrosion had got into the seal and it wasnt releasing as it should. i picked up a new caliper but i cant get the parking brake cable out of the caliper. i have soaked it with penetrating fluid and will leave it overnight and see if that helps. I'm all ears if anybody has any suggestions.
the parking brake works fine. i can release the cable from the caliper its the outer sleeve is stuck in the caliper housing. i got the caliper working and will take it to the mechanic. either he will get it out or i will need a new parking brake cable too
