Results 1 to 14 of 14
Thread: Dealer can't find problem in CX5 that blows fuses
  1. #1
    Registered Member
    Join Date
    Nov 2019
    Posts
    5
    I'll make this as short as possible, but I think the chain of events is important to figure out what to do:
    1. Daughter leaves interior light on on 2015 CX5. Battery dies.
    2. Tow truck driver apparently connects jumper cables wrong; then corrects himself and car starts.
    3. All lights on dash illuminated. Power steering doesn't work. Car can be started, however.
    4. Tows car to Trusted Mechanic who doesn't do electrical, so then car is towed to dealer.
    5. Dealer replaces fuse**, charges her $180, and sends her on her way.
    ** There is some question as to whether this is a 7.5A fuse in fuse box or main fuse on battery.
    6. Daughter drives car to East Jesus in Central Valley of CA and problem happens again but without jump start this time.
    7. Has car towed back to dealer. Dealer spends a week but cannot find problem. Apparently replaces same 7.5A fuse.
    8. Diagnosis: either the power steering, ABS, or SRS module needs to be replaced. Cannot determine which. Dealer says we'll put in a new SRS module ($1300) and see if that fixes it.
    I now have the challenging decision of either allowing my daughter to drive a potentially dangerous car, or to blindly replace "modules" in the hope that it will solve the problem.
    What do I do?
    Thanks,
    Chuck Hawley, new member and really in need of some good news.
  2. #2
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,468
    Does the dealer know about the tow truck driver's screw up? That kind of mistake can be harmful in so many ways...
  3. #3
    Registered Member
    17 Mazda 6 GT
    Join Date
    Apr 2017
    Location
    Ontario, Canada
    Posts
    651
    Make sure you document everything. Keep all receipts and a log of the activities you have had to endure.
    This way when the vehicle is finally fixed, you can go after the tow truck driver/company for reimbursement.
    No way should you be paying for his screw up.
    Hooking up the cables backwards on today's vehicles, with all the electronics in there, is a sure fire way to fry something.
  4. #4
    Registered Member Ronzuki's Avatar
    2018 CX-5 Touring AWD
    Join Date
    Jun 2018
    Location
    Lancaster, PA
    Posts
    28
    Everything on that 7.5A circuit (or what ever it is, which is pretty important info to know in order to diag) is suspect at this point after the tow truck driver's screw-up. Since the PS didn't work initially after said screw-up as you say, and it's electric, I'd say that's a great place to start digging. Presumably the PS worked after mystery fuse was replaced the first time. It is now blown again, and presumably, the PS is no longer working, again? If not, the PS clearly was not happy about the reverse polarity condition. Doesn't mean anything else on that circuit, or the entire car for that matter, isn't subject to pre-mature failure. Reverse polarity protection is probably not something the nave automotive automation engineers have thought a need for...yet. that sort of 'feature' in controls and components costs more for certain. Dealer needs to know this occurred and you will likely need to fight the towing company to be reimbursed for the fix(es) which Mazda certainly won't cover when they learn the truth...which they'll need to know so they can fix the car.
    Ron
    ____________________
    2018 CX-5 Touring AWD Eternal Blue Mica
    2011 Suzuki SX4 iAWD
    2010 Suzuki Kizashi GTS iAWD
  5. #5
    Registered Member
    Join Date
    Nov 2019
    Posts
    5
    Good idea re: documentation. Tow truck company owner is an a**hole, and was very rude to my daughter when she contacted him. Has TERRIBLE reviews on Yelp. Shoulda know better...
    Chuck
  6. #6
    Registered Member
    Join Date
    Nov 2019
    Posts
    5
    There are about six 7.5A fuses, and one of them is identified as the SRS circuit. There is a 50A fuse for the ABS/Stability System. I can't find any fuse for power steering.
    This appears to happen when the car is at rest.
    I think the dealer, as well as Mazda US has given up, and is now in the mode of replacing expensive parts until the car stops failing...
  7. #7
    Registered Member
    Donated: $15
    Join Date
    Mar 2013
    Location
    Posts
    1,468
    Quote Originally Posted by chuckhawley View Post
    Chuck
    It wasn't AAA by any chance, was it?
  8. #8
    Registered Member
    Join Date
    Oct 2019
    Posts
    55
    I'd start by replacing all of the 7.5A fuses as well as the 50A fuse. The reverse poliarity may have fried something in more than one fuse, so the problem continues to exist as the chain remains broken despite the replacement of one fuse only. It's a cheap enough fix, and just may do the trick. If it doesn't, then you should try an experienced mechanic, other than the dealer ... replacing expensive modules blindly is no way to run a service department.
  9. #9
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,761
    Fuses blow for a reason. All the fuses were checked(in the whole car)? They check out OK?
    I would start watching some Youtube videos, like this one:
    https://www.youtube.com/watch?v=lQowZNSrffA
  10. #10
    Registered Member
    Join Date
    Nov 2019
    Posts
    5
    Quote Originally Posted by madar View Post
    No, as it turns out, it was the recommended tower for State Farm. Incidentally, we've had a series of not-our-fault accidents among my daughters, and State Farm has been A+ in taking care of the claims. I wouldn't normally call out an insurance company, but they have been fast and generous.
  11. #11
    Registered Member
    Join Date
    Nov 2019
    Posts
    5
    Quote Originally Posted by Joe Willie View Post
    ...replacing expensive modules blindly is no way to run a service department.
    Truth! I'd be embarrassed to recommend that "strategy" to a customer...
  12. #12
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,917
    YOUTUBE watch by tibimakai above is the way to check this problem.
  13. #13
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    State of Jefferson - SO Oregon
    Posts
    2,628
    Quote Originally Posted by tibimakai View Post
    Unbelievable!
    Thanks for that link.
    Great job. I liked his beat up hands. No gloves.
  14. #14
    Registered Member
    2010 Mazda 5 Sport
    Join Date
    May 2019
    Posts
    128
    If the circuit is blowing fuses and all the devices attached to the circuit check out. Then it's the wiring harness. A wire got partially melted and is shorting.
    Oh, and you need to dump this Mazda dealer. These guys are idiots.
Similar Threads
  1. Climate Control and Sunroof Blows Fuses
    By tmallik in forum Mazda6 Infotainment
    Last Post: 01-02-2015, 07:45 PM
  2. Replies: 7
    Last Post: 01-26-2013, 11:28 PM
  3. NEED to find my problem Any ideas????
    By alexB in forum Mazdaspeed Protege
    Last Post: 04-11-2008, 07:40 PM
  4. Emergency Help, Dealer can't find the problem either!!!
    By Speed3.5 in forum Mazdaspeed Protege
    Last Post: 01-20-2008, 11:29 PM
  5. A/C Problem, about to visit dealer. :(
    By fastdrvr23 in forum Protege5
    Last Post: 08-15-2002, 10:36 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
