Thanks. Do you know if it levels "on the fly", or is it only supposed to level the headlights upon startup?
The reason I ask is because the other day, I bought a pair of 145 lb dumbbells from a kijiji seller. When I went to pick them up, I put the car in Park and left it to idle while I loaded both dumbbells into the trunk of the car. I secured them close to the liftgate opening. I then drove home, but on the way home I could tell that the headlight cutoff level was higher than normal, due to the weight at the rear-most part of the car. I paid it no mind and thought that they would level out during the drive home, but they never did. After unloading the dumbbells, the headlight's cutoff level went back to normal, as expected.
I found this odd because there have been a few times while I was driving with no cargo at all, and the headlights would adjust the headlight cutoff down a little bit, as soon as I came to a stop in traffic (car in gear, foot on the brake).
I think I'll bring it up with the dealer when I have time, but if anyone has any insight in the meantime, please let me know.
