Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Rear “fog light” - bumper reflector lights installation.
  1. #1
    Registered Member
    2019 CX-5 Signature
    Join Date
    Mar 2019
    Location
    Southern NJ
    Posts
    44
    So this was interesting (and still is).
    I was able to install some of the aliexpress/eBay rear bumper lights. That part was easy. Drop lower trim panels in the rear, install new lights and run wire up through grommet into rear quarter panels.
    Then I installed the wiring onto the turn signal lights. It took some trial and error but the turn signals and running/parking lights worked fine. The lights themselves came with a green, yellow, red and black wire. No wiring diagrams are available for the lights (naturally).
    Here*s the two issues I ran into.
    1. The brake light never worked. When I hit the brakes, the bumper lights turned off instead of getting brighter. Not sure why and not even sure I found the proper brake light wire.
    2. Even worse, once I had everything wired up (clearly, there*s an issue with my selected wires) I started getting all sorts of codes/DTCs and errors at the front of my car in the instrument panel. Errors like smart braking control failure, front sensor error, etc. All hell broke loose. Needless to say, I disconnected all the wires and everything is back to normal.
    Does anyone have a wiring diagram for the 2019? I*ve tried every combination and I can*t get the brake light to work and my current wiring scenario causes havoc on the car*s computer.
    They looked great for the hour or so I had them connected!
    Edit: just to clarify, these are not true fog lights, they are turn/park/brake indicator lights that replace the reflectors in the lower rear bumper.
  2. #2
    Registered Member
    Join Date
    Oct 2019
    Posts
    7
    https://www.mazdas247.com/forum/show...717-My-2017-KF
    I did this instead, not rear fog but driving, brake, turn signal. Check the youtude video as well, short but you get the idea. Use the search, there's already a post here about adding rear fogs.
  3. #3
    Registered Member
    2019 CX-5 Signature
    Join Date
    Mar 2019
    Location
    Southern NJ
    Posts
    44
    I*ve searched quite a few times. I*ve also read all the threads on rear fogs.
    The issue is that I cannot find actual wiring diagrams/instructions.
  4. #4
  5. #5
    Registered Member
    2019 CX-5 Signature
    Join Date
    Mar 2019
    Location
    Southern NJ
    Posts
    44
    Thank Max! Got them all working. Once you pointed out my stupidity (green isn*t ground in automotive wiring) it works perfectly.
  6. #6
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,351
    Usually a ground is black or brown, green though? Lol
  7. #7
    Registered Member
    2019 CX-5 Signature
    Join Date
    Mar 2019
    Location
    Southern NJ
    Posts
    44
    I mean, for 110V home wiring it is. Admittedly, I had a major brain fart and wasn*t thinking.
    Having said all that, $45 well spent! They look stock and really sharp in parallel with the signature*s rear LED lights.
  8. #8
    Registered Member
    Join Date
    Oct 2019
    Posts
    7
    Glad you finally got them working. They look and feel like factory.
  9. #9
    Registered Member
    2019 CX-5 GTR
    Join Date
    Jul 2019
    Location
    South of Houston
    Posts
    4
  10. #10
    Registered Member
    2019 CX-5 Signature
    Join Date
    Mar 2019
    Location
    Southern NJ
    Posts
    44
    That is exactly what I just installed. I wish I had seen the wiring diagram on your link before I attempted mine. Very happy with the results.
  11. #11
    Registered Member
    2018 Mazda CX-5 GT
    Join Date
    Feb 2019
    Location
    IL
    Posts
    8
    Do you have instruction on which wire to tap into?
  12. #12
    Registered Member
    2019 CX-5 Signature
    Join Date
    Mar 2019
    Location
    Southern NJ
    Posts
    44
    Here*s what I did (I*m doing this from memory and after some trial and a lot of error):
    Green light wire to green car wire
    Yellow light wire to blue car wire
    Black light wire to ground (there*s ground blocks and screws right next to light wiring in the rear quarter panels)
    Red light wire to pink with stripe car wire
    I used T-locks to connect the wires to the car wiring and opted for the wires just before the junction that goes right to the rear lights themselves (basically I disconnected the rear lights at the rear quarter panels and connected the wires that feed that connector). If you*re really in a jam I can take it apart and snap some photos but it*s pretty easy once you have things apart.
    You can go to e-trailer website and look at video for installing the trailer harness t-harness. That will cover the disassembly of the rear panels and show you the wiring as well.
  13. #13
    Registered Member
    2018 CX-5 GT Silver / 2003 MX-5 SE JRSC
    Join Date
    Dec 2018
    Location
    South Carolina Coast
    Posts
    59
    How was the actual fitment on the vehicle, did it fill the existing area well? The corners on my lights look pointed and these appear to be rounded. And how long was the wiring ?
    2018 Mazda CX-5 Grand Touring ...adding bling, Front and rear sequential turn signals
    2003 Mazda MX-5 SE Supercharged JRSC MP62 (SOLD) but not forgotten
  14. #14
    Registered Member
    2019 CX-5 Signature
    Join Date
    Mar 2019
    Location
    Southern NJ
    Posts
    44
    It looks OEM to me. I*ll try and snap some photos later. Zero issues with that fit and there are no gaps.
    The wiring was more than adequate to go from the mounting location through the grommets into the rear quarter panel. If I was guessing, I have 2-3 feet of wiring left after splicing. I had enough to coil some up and leave a service loop of wire should I ever need to fix anything in the future.
  15. #15
    Registered Member
    2019 Mazda CX-5 Signature
    Join Date
    May 2019
    Location
    Belleair Beach, Florida
    Posts
    99
    I'm considering doing this but I'm concerned in replacing the OEM passive reflectors with a light fixture. The purpose of those reflectors is to make a parked or un-illuminated vehicle more visible to another vehicle approaching from the rear (or rear-quarters). Do those nice LED fixtures also have embedded reflectors? What about side quarters?
    I know they have the words "Reflector Lights" in the product title, but I can't see any metallic multi-faceted reflector characteristics in the photos. The non-illuminated part looks to me like its just translucent red plastic. The lighter strips are un-masked areas that the LED's illuminate through. Not much reflectivity. See the photos CharlestonMX5 posted below.
Similar Threads
  1. 2013~2016 Anyone tried the LED rear bumper reflector replacements?
    By PatrickGSR94 in forum CX-5 Accessories & Appearance
    Last Post: 04-25-2019, 12:15 PM
  2. Rear reflector & front vent (aftermarket lights)
    By XIA CX9 17 in forum CX-9 General
    Last Post: 09-27-2018, 04:20 PM
  3. 2012+ Mazda 5 Rear LED Reflector installation help!
    By mzoomalohahi5 in forum Mazda5
    Last Post: 01-22-2017, 02:24 AM
  4. Problem with rear bumper reflector (broken)
    By right2002 in forum CX-5 General
    Last Post: 10-25-2013, 07:40 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
