Page 1 of 4 123 ... LastLast
Results 1 to 15 of 46
Thread: Left Doors Unlocked
  1. #1
    Pitter Pitter's Avatar
    Donated: $25
    2020 CX-5 Signature Azul Metalico
    Join Date
    Aug 2019
    Location
    Cali, Colombia
    Posts
    296
    Left Doors Unlocked
    Yesterday I came home, unloaded the groceries and went into the house. Had the "key" in my pocket. This morning I went out and the mirrors were sticking out and the doors were unlocked. How'd that happen? I certainly don't want a repeat when I'm in the city.
  2. #2
    Registered Member
    2019 CX-5 Reserve
    Join Date
    May 2015
    Location
    South Florida
    Posts
    119
    Did you lock the doors before you went in the house? Maybe the unlock button got pressed in your pocket. Maybe your neighbors have hacking software. Could be any number of possibilities. Not sure how to prove/disprove any of them.
  3. #3
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    State of Jefferson - SO Oregon
    Posts
    2,638
    Quote Originally Posted by Pitter View Post
    Happens to me every once in awhile. You have it set to auto lock? If you walk away too fast, it may not lock. There's another thread discussing this at length.
    That said, I always listen for the second beep, so it may be that it occasionally performs outside of it's intended parameters, aka fails, like so many of our electronic aids.
  4. #4
    Registered Member
    Join Date
    Apr 2019
    Posts
    224
    If I don't press the lock button, my doors don't lock either
  5. #5
    Registered Member
    2019 Mazda CX-5 GT Reserve
    Join Date
    Sep 2019
    Location
    PA
    Posts
    52
    Quote Originally Posted by shadonoz View Post
    I experience the same occasionally. Autolock with "walkaway mode". If I walk away too fast sometimes it doesn't autolock. As pointed out, listen for the second beep.
  6. #6
    Harpy Eagle Chocolate's Avatar
    2019 Mazda CX-5 AWD
    Join Date
    Aug 2019
    Posts
    411
    On my Sport, pressing the lock button on the keyfob 3x sounds the horn very briefly so you know the vehicle is locked. I don't know if the antenna key versions are the same.
  7. #7
    Donated: $25
    Join Date
    Aug 2019
    Location
    Cali, Colombia
    Posts
    296
    Thanks very much, I guess I walked away too fast.
  8. #8
    Registered Member
    2019 CX-5 Touring
    Join Date
    Feb 2017
    Location
    Utah
    Posts
    64
    I haven't quite figured it out but when any door besides the driver's is opened, there's some situations where the doors don't automatically lock. I think they have always automatically locked when only the driver's door gets opened.
  9. #9
    Registered Member
    Mazda 6 Tourer
    Join Date
    Oct 2019
    Location
    Scotland
    Posts
    1
    If you close the tailgate AFTER you close the car doors then the car will NOT lock.
    Open and close a door after you have unloaded the groceries.
    If you close the door with the key "out of range" it will NOT lock. This can be as little as a metre or a yard.
    The car should "beep" when the door is closed and the key is in range and "beep again" when the key moves away.
    Ours is a UK model but I do not see that yours can be different.
  10. #10
    Registered Member
    2019 CX-5 Touring
    Join Date
    Feb 2017
    Location
    Utah
    Posts
    64
    Quote Originally Posted by aljshep View Post
    Oh, thank you for the details! A passenger closing their door after I'm (and the key in my pocket) out of range is probably the scenario I've encountered but I just didn't know exactly why.
  11. #11
    Registered Member
    Contributor
    2019 CX-5 Reserve Eternal Blue
    Join Date
    Aug 2018
    Location
    Central Virginia, USA...the winding rural part
    Posts
    1,528
    I have mine set on Auto Lock.
    It seems that the Auto Lock either does not work or is disabled (or there's some weird sequence of events) if I open the hatch to get my groceries out. When I close the driver's door when the hatch is open and then close the hatch, it's as though Auto Lock does not work.
    So it seems. I have not tested this.
    A few days ago I had my first instance of walking up to my car after shopping and realizing I had left the thing running. I've almost done this once before. Damned keyless stuff...
  12. #12
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    Posts
    2,638
    Quote Originally Posted by Avoidin Deer View Post
    You are correct. Doesn't make sense to me, but seems to be by design.
  13. #13
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    562
    Quote Originally Posted by Chocolate View Post
    I got used to pressing the lock button on the door as I exit, since it is hard to hear the car lock when pressing the fob and I rather not hear the horn beep by pressing the fob button again.
  14. #14
    Registered Member
    Contributor
    Join Date
    Aug 2018
    Location
    Posts
    1,528
    I wonder if the problem is that I walk away as the hatch is closing, and I'm out of range when it locks.
    I'll try staying there as the hatch closes and see if that makes a difference. I can't pick through the 26 mind-numbing pages of the manual on keys/doors/locks tonight to see if this is addressed. It makes my eyes glaze over. SO many options on functionality & behaviour & #beeps.
  15. #15
    Registered Member
    Contributor
    Join Date
    Aug 2018
    Location
    Posts
    1,528
    I have the Walk Away feature turned on.
    When I close the driver's door and have the fob on me (outside of the car), I get an initial Beep. When I walk away, it Beeps a couple of times to let me know that it locked. I believe the lights flash as well when it locks...I think.
Similar Threads
  1. wtb left doors
    By repthemazdas in forum Completed Transactions
    Last Post: 08-04-2010, 08:07 PM
  2. unlocked iphone
    By SPEEDYHANS in forum Completed Transactions
    Last Post: 07-14-2009, 09:13 AM
  3. iphone unlocked
    By SPEEDYHANS in forum Global
    Last Post: 07-11-2009, 09:29 AM
  4. ??just unlocked new powerband???
    By 4doors&atrunk in forum Mazdaspeed Protege
    Last Post: 08-24-2006, 07:38 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
