Results 1 to 9 of 9
Thread: 2019 GTR First Oil Change Question (metal)
  1. #1
    Registered Member
    Join Date
    Sep 2019
    Posts
    5
    Just did the first oil change at 1600 miles. I noticed some metal in the oil drain pan. Not a ton, maybe like a small pinch of salt amount. Got bored and also tore down the oil filter (actually kinda meh construction imho). Kinda sparkly but not terrible, mostly settled on the bottom of the filter nothing as large as what was in the pan. Pan particles were about table salt size.
    Mostly concerned about finding metal in the oil drain pan. I feel it's normal on the first oil change but this is only the second new car i've owned. Anyone else think it's normal/ not normal? Maybe more because it also has the turbo in it so more parts are seating themselves?
  2. #2
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    338
    do used oil analysis and compare with the posts in the main thread.
    Everything else is speculative.
    Usually its normal although I havent seen anything visible in my first oil change but it did show elevated metals on my used oil analysis.
  3. #3
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,426
    Arrow 2019 GTR First Oil Change Question (metal)
    Quote Originally Posted by osrk View Post
    You shouldnít be able to ďseeĒ any metal from factory oil. Like cz5gt I havenít seen anything like this from a few new cars Iíve owned. IMO your description is not normal.
    Yeah,send your oil sample for a UOA to get more accurate report of your drained oil.
  4. #4
    Registered Member
    Soon to be 2.5T CX-5
    Join Date
    Jul 2019
    Posts
    245
    Normal. A pinch of salt is nothing. Now if you'd said it was an entire shaker of salt, then I'd be alarmed. Sounds like the filter did it's job to me.
  5. #5
    Registered Member
    Join Date
    Sep 2019
    Posts
    5
    Quote Originally Posted by yrwei52 View Post
    On closer inspection is was actually mostly or all dirt. I was doing this at night so the lighting wasnít as good are during the day. I crushed a few pieces and they burst apart versus deformed. I did think it was very odd to see as they were small enough for me to think the filter would be able to pick them up and trap them especially given the turbulence inside the engine oil reservoir.
    Will definitely clean out the oil drain pan better next oil change and see. I didnít keep the oil from this change to send out (put it the used oil can with all the other oils). I think I will next oil change.
    Tearing down the Mazda OEM filter was interesting. Iím not sure who said itís highly rated or why. It definitely seemed middle of the road. I tore down a Honda A1 filter as well and it seemed to be better.
  6. #6
    Gen-1 Kodo Design 👌 ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,408
    On closer inspection is was actually mostly or all dirt. I was doing this at night so the lighting wasn*t as good are during the day. I crushed a few pieces and they burst apart versus deformed. I did think it was very odd to see as they were small enough for me to think the filter would be able to pick them up and trap them especially given the turbulence inside the engine oil reservoir.
    Will definitely clean out the oil drain pan better next oil change and see. I didn*t keep the oil from this change to send out (put it the used oil can with all the other oils). I think I will next oil change.
    Tearing down the Mazda OEM filter was interesting. I*m not sure who said it*s highly rated or why. It definitely seemed middle of the road. I tore down a Honda A1 filter as well and it seemed to be better.
    GTR I believe uses a different oil filter than the 2.5L non-turbo. The factory Tokyo Roki filters on the 2.5L are very well regarded here and on BITOG, etc.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 87k miles
    01/2013 build | 4/20/2013 delivery
  7. #7
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    584
    You shouldn*t be able to *see* any metal from factory oil. Like cz5gt I haven*t seen anything like this from a few new cars I*ve owned. IMO your description is not normal.
    I didn't comment on his post because nothing he said makes sense. It sounds like he removes the oil pan to change the oil which doesn't make sense. Plus like you said there should be no metal or dirt particles in the oil out of the pan unless they are unusually heavy or large. The oil in the pan is filtered oil.
  8. #8
    Registered Member
    Mazda CX-5
    Join Date
    Dec 2015
    Location
    Chattavegas
    Posts
    383
    No pics so can't see, but a little metal in the first oil change is not surprising. That's why I make the first change at 1000 miles.
  9. #9
    Registered Member
    Join Date
    Oct 2019
    Posts
    72
    Spoke to a friend who's a Mazda tech. He said the first oil change should not be done before 7,500 miles. According to him, the initial oil contains a very high concentration of moly, which is good for engine break-in ... and, yes, despite what Mazda says, there is a break-in period beyond what's stated in the manual.
Similar Threads
  1. Replies: 16
    Last Post: 09-10-2019, 07:23 PM
  2. Replies: 10
    Last Post: 06-18-2019, 10:17 AM
  3. 2019 Oil Change - Fumoto Plug
    By cpotter638 in forum CX-9 General
    Last Post: 06-15-2019, 10:57 PM
  4. Replies: 9
    Last Post: 12-21-2018, 04:37 PM
  5. Replies: 13
    Last Post: 11-07-2010, 09:36 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
