Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Shouldn't low FOB battery show up on Dash?
  1. #16
    Registered Member
    2018 cx5 GT
    Join Date
    Feb 2019
    Location
    BC Canada
    Posts
    94
    Most people*s lasted about a year. On average.
  2. #17
    Registered Member 7eregrine's Avatar
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    5,125
    Quote Originally Posted by wlong01 View Post
    I don't know if I can buy the bad spot.
    It's happened to me at least a half dozen times in 3 years. Happens once upon entry and then not again for weeks.
    Battery going on 3 years and still original. I don't think 12 months is 'standard' for battery life.
    Beware Amazon batteries. I'm not buying those again. Bought 6 for my Volvo. Went through 5 of them in about 7 months. 6 should have lasted for years...
  3. #18
    Registered Member
    2019 CX5 Reserve AWD
    Join Date
    May 2015
    Location
    Delaware
    Posts
    743
    Quote Originally Posted by 7eregrine View Post
    Beware Amazon batteries. I'm not buying those again. Bought 6 for my Volvo. Went through 5 of them in about 7 months. 67 should have lasted for years...
    Beware Amazon anything. You have to be careful and make sure they're a trusted seller. Amazon is more like the middleman now, just takes the order and money and gives it to a remote seller. I've always had good luck with Amazon until recently. Ordered some cables and there was blatant false advertising. Luckily Amazon refunded my money.
  4. #19
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    5,125
    Agree. Absolutely having more issues lately.
  5. #20
    Registered Member Conrad 16.5's Avatar
    2016.5 CX-5 Grand Touring AWD titanium/black
    Join Date
    Sep 2016
    Location
    Northern Illinois
    Posts
    977
    You get in the car with fob. You press button. Car looks for fob. Car detects faint signal. This is why it will work if you press it close to the button. It will never get to UTTERLY DEAD status unless you ignore it for weeks.
    Totally my theory, no facts included here.
    @OP: I've had this exact thing happen. It is probably just in a bad spot and didn't get the good detection on the signal. I think the car just didn't get a good 'look' at the key and assumes the battery is dead. Subsequent starts it 'sees' the key better.
    Close, but no cigar. (1995 called and asked me to explain it to you)
    There are two independent systems working in your fob.
    One uses battery power to 'broadcast' the signal to the car that it's ok to start once it 'sees' that the car is requesting authentication.
    The other system uses a proximity RFID chip in the fob that doesn't require battery power. That's why you have to place the fob close to the start switch. There's an induction coil near the switch that induces enough current in the fob to power the RFID chip.
    Don't believe me? Remove the battery from your fob and see if it works by placing it near the Start switch.
    "Don't bother me with facts, Son. I've already made up my mind." -Foghorn Leghorn
  6. #21
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    5,125
    Quote Originally Posted by Conrad 16.5 View Post
    Why would I doubt you? I clearly stated I was guessing here.
  7. #22
    Work in Progress sm1ke's Avatar
    Donated: $25
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,907
    Quote Originally Posted by Avoidin Deer View Post
    But there's a "Battery Dead" warning. Is there a way to detect the key if its battery is dead? (Honest question, there's RFID technology that does not require a power source.) There's got to be a way to know there's a key present to tell you that its battery is dead.
    Does it actually say "Battery Dead"? If so, I could see that warning coming up when the fob no longer unlocks the door and you have to use the physical key. Maybe the Battery Dead warning is triggered by the RFID.
  8. #23
    Registered Member
    2016.5 CX-5 Sport
    Join Date
    Mar 2016
    Location
    Boise, Idaho
    Posts
    110
    Use the fob to press the start button when it is low. I've went a week like that.
  9. #24
    Registered Member
    2019 CX-5 Reserve Eternal Blue
    Join Date
    Aug 2018
    Location
    Central Virginia, USA...the winding rural part
    Posts
    1,348
    That's what I was questioning earlier. So you can get a warning light saying Fob Battery Dead because the RFID chip tells the system that there's a fob nearby.
  10. #25
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,348
    Quote Originally Posted by sm1ke View Post
    Yeh, it says "Battery Dead" in the 2019 manual.
    I'm thinking what you said: RFID sees a key is there, but it's not transmitting. Except RFID does not have that great a range, but I can't think of anything else.
  11. #26
    Registered Member
    Join Date
    May 2015
    Location
    Delaware
    Posts
    743
    Think I figured out the problem with the fob.
    Went out this morning, fob in pocket, put my foot on the brake, no light on start button. Took the fob out, put it right next to the start button - nothing Then I noticed the brake was locked up tight, pressed the brake hard and felt something like a contact switch, then the green light came on. For some reason in the morning the brake pedal is locked tight.
    I'm used to just putting my foot on the brake with light pressure. It's that way all during the day but when it sits overnight the brake gets really tight requiring a lot of pressure to move the pedal. Once it starts the brake feels normal.
  12. #27
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,348
    Now you may have another problem, huh?
    I've got a Reserve. I use my Parking Brake all the time, and have never had that issue. I'm retired and the car has sat for a couple of days without being driven.
    I wonder what's going on...maybe something with the power assist unit?
  13. #28
    Registered Member
    2019 CX-5 Sig
    Join Date
    Feb 2013
    Location
    Fairfax, VA
    Posts
    196
    OP: Try this next time you get in your car first thing in the morning: don't press the brake pedal and push the ignition switch. If the key fob is being detected, the car won't start but the car will go into accessory mode. If nothing happens, the fob isn't being detected.
Similar Threads
  1. Dash lights and battery issues- 2008 GT
    By SC300ES in forum CX-9 Engine & Transmission
    Last Post: 03-03-2017, 05:31 PM
  2. Battery light in dash is on
    By buliwyf in forum Protege5
    Last Post: 10-22-2014, 04:47 PM
  3. Replies: 31
    Last Post: 10-09-2013, 12:06 PM
  4. Shouldn't radio show the name of the song being played?
    By dcarlsen in forum CX-9 Infotainment
    Last Post: 12-31-2010, 11:11 AM
  5. A couple of dash pics from NY Auto Show
    By lilarry in forum Mazda CX-7
    Last Post: 05-31-2006, 11:39 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
