Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: Shouldn't low FOB battery show up on Dash?
  1. #1
    Registered Member
    2019 CX5 Reserve AWD
    Join Date
    May 2015
    Location
    Delaware
    Posts
    735
    For the last 4 days when I went to start the car in the morning, nothing, no green, orange, red on the start button. When I take the FOB and wave it around close to the start button it will eventually turn green and start.
    The rest of the day it works fine, even when it's in my pocket.
    I thought I would get a low battery warning on the dash if indeed the battery is low.
    Don't have access to the other FOB right now but will check it when my wife returns from out of town.
    Wonder if these FOB batteries sit around or if the dealer refreshes them when you take delivery of the vehicle.
  2. #2
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    State of Jefferson - SO Oregon
    Posts
    2,519
    Quote Originally Posted by wlong01 View Post
    You should. I've gotten the warning on both of my original batteries. One after about 18 months, the next after about 6 month [2 years after delivery]. The warning came before any malfunctions.
    They're standard cr2025s. They can't be recharged, and I'm sure the dealer doesn't replace them when new.
    Since you have a 19, it seems too soon for the battery to fail, but always check that first!
  3. #3
    Registered Member
    2019 CX-5 Reserve Eternal Blue
    Join Date
    Aug 2018
    Location
    Central Virginia, USA...the winding rural part
    Posts
    1,334
    The thing that makes no sense to me is the Key Warning Indicator is supposed to be white if the FOB battery is dead. But how would it even know the FOB is in the car if the battery in it is dead?
  4. #4
    Registered Member 7eregrine's Avatar
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    5,125
    You get in the car with fob. You press button. Car looks for fob. Car detects faint signal. This is why it will work if you press it close to the button. It will never get to UTTERLY DEAD status unless you ignore it for weeks.
    Totally my theory, no facts included here.
    @OP: I've had this exact thing happen. It is probably just in a bad spot and didn't get the good detection on the signal. I think the car just didn't get a good 'look' at the key and assumes the battery is dead. Subsequent starts it 'sees' the key better.
  5. #5
    Registered Member
    2019 CX-5 Signature Soul Red Crystal
    Join Date
    Aug 2019
    Posts
    41
    How long does it take a new fob to drain to 0%?
  6. #6
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,334
    Quote Originally Posted by 7eregrine View Post
    So in theory, I should be able to get into the car with no FOB on me, press the button, and the FOB Battery indicator should say Dead Battery.
    I'll have to give it a try.
  7. #7
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,334
    Quote Originally Posted by mutualcore View Post
    It would likely depend on how often you push the buttons on it.
    I have my doors automatically "Walk Away Lock," so I never use the FOB's transmitter to lock/unlock them or to open the hatch. My battery is likely to last the longest under those conditions.
  8. #8
  9. #9
    Work in Progress sm1ke's Avatar
    Donated: $25
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,895
    Quote Originally Posted by Avoidin Deer View Post
    I think you'd get a "Key Not Detected" error. The car needs to be able to detect the key in order to determine if the battery is low.
  10. #10
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    Posts
    2,519
    Quote Originally Posted by sm1ke View Post
    Mine first says "key not detected" and then "low battery".
    So it does NOT need to detect the key. If it doesn't detect it, it assumes the battery might be low.
  11. #11
    Registered Member
    Join Date
    May 2015
    Location
    Delaware
    Posts
    735
    I don't know if I can buy the bad spot. I've had my 16 for 4 yrs and wear the same type of pants/shorts and it has never missed. Plus on the 19 it detects the FOB since it lets me unlock the drivers door with the FOB in my pants pocket. I will change the battery when I'm able to and go from there
    It's weird because I went out this morning and had trouble. Went out two times after that later and no problem. Same pants, FOB in same pocket.
  12. #12
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,334
    Change your battery and see if that fixes it.
    If not, use the other fob for a while and start to narrow down the problem point.
    ps: Apologies for using upper case letters for fob. It's a noun, not an acronym for Free On Board. Five years into retirement and I just can't break the habit.
  13. #13
    Gen-1 Kodo Design 👌 ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,312
    My first FOB battery lasted 3 years. I probably prematurely replaced it again a couple years after when I thought it was dead again, but ended up being a switch under the gated shifted in my 2014.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 86k miles
    01/2013 build | 4/20/2013 delivery
  14. #14
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,334
    But there's a "Battery Dead" warning. Is there a way to detect the key if its battery is dead? (Honest question, there's RFID technology that does not require a power source.) There's got to be a way to know there's a key present to tell you that its battery is dead.
  15. #15
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    Posts
    2,519
    Guess you didn't see this, or didn't understand the implications.
    Quote Originally Posted by shadonoz View Post
    It gives the low battery warning when the battery reaches a voltage threshold, long before it ever goes dead.
Similar Threads
  1. Dash lights and battery issues- 2008 GT
    By SC300ES in forum CX-9 Engine & Transmission
    Last Post: 03-03-2017, 05:31 PM
  2. Battery light in dash is on
    By buliwyf in forum Protege5
    Last Post: 10-22-2014, 04:47 PM
  3. Replies: 31
    Last Post: 10-09-2013, 12:06 PM
  4. Shouldn't radio show the name of the song being played?
    By dcarlsen in forum CX-9 Infotainment
    Last Post: 12-31-2010, 11:11 AM
  5. A couple of dash pics from NY Auto Show
    By lilarry in forum Mazda CX-7
    Last Post: 05-31-2006, 11:39 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
