In Memory of Member 1338
Results 1 to 3 of 3
Thread: 1.8 Ignition Coil Conversion
  1. #1
    Registered Member
    Join Date
    Aug 2019
    Posts
    6
    So I got the 1.8 engine ignition coils and I got the 626 Valve cover today. However I could not find the bracket for the ignition coil pack. Are there any alternatives? I know the 626 has a bracket as well but it's a little different. Am I screwed and can only get it from 00-01 Protege?
  2. #2
    Registered Member
    2001 Mazda SP20 323
    Join Date
    May 2017
    Location
    Hamilton, NZ
    Posts
    138
    626 bracket should fit, I think you have to move the big block of earth connectors from memory, but it should work
    Junk yards might be your best bet for getting a bracket, should be fairly cheap too
    Otherwise you can fab up a bracket that sits on top of the intake manifold (like mine lol)
  3. #3
    Registered Member
    Join Date
    Aug 2019
    Posts
    6
    You memory serves you correct. I gave up on trying to remove it cause there was a lot of stuff in the way at the time. Still, I need it, so I shall be making a trip back. Thanks the reply!
Similar Threads
  1. Oil on ignition coil?
    By RamoNash in forum Mazda3 Engine & Transmission
    Last Post: 02-12-2011, 10:55 PM
  2. Ignition Coil Conversion
    By bigboi in forum Other Mazdas
    Last Post: 06-03-2010, 04:53 PM
  3. Ignition Coil
    By Dragg1e in forum Mazda Protege
    Last Post: 12-07-2009, 03:08 PM
  4. MS3 Ignition Coil Mod
    By knowledge007 in forum Mazdaspeed3
    Last Post: 07-24-2008, 05:46 AM
  5. 1.8 - 2.0 Ignition Coil ?
    By gimpo2 in forum Mazda Protege
    Last Post: 10-03-2005, 05:11 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
