Results 1 to 9 of 9
Thread: Keep Using "Mazda Full Synthetic 0W-20 Gf-5 With Moly Engine Oil" for oil changes?
  1. #1
    Registered Member
    Join Date
    Aug 2019
    Posts
    2
    Thanks to this community I have been using the"Mazda Full Synthetic 0W-20 Gf-5 With Moly Engine Oil" for my oil changes (3 so far) on my 2018 CX-5 GT.
    I buy the 1QT sizes at the dealer and have them change out the oil etc.
    My question is : is it bad to keep using this Molly oil for the life of the car? will too much Molly ultimately be too much of a good thing? should I begin using what the manual suggests: SAE 0W-20 Castrol or whatever the dealers put in which I assume is SAE 0W-20 Castrol?
    thanks for any input.
  2. #2
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,906
    Your MAZDA engine will have a long and happy life running MAZDA Moly engine oil throughout its life. Ed
  3. #3
    Registered Member Conrad 16.5's Avatar
    2016.5 CX-5 Grand Touring AWD titanium/black
    Join Date
    Sep 2016
    Location
    Northern Illinois
    Posts
    977
    There's no reason not to keep using this Mazda oil, that's what I plan on doing. Except that I do all my own work. Other than that, carry on.
    "Don't bother me with facts, Son. I've already made up my mind." -Foghorn Leghorn
  4. #4
    Registered Member
    Soon to be 2.5T CX-5
    Join Date
    Jul 2019
    Posts
    189
    No reason at all to stop using it. Only reason I did was to save money. Using Penn Platinum like a lot of folks here, but the Castrol Edge, Mobil1, and even Rotella truck will do you just as good if you chose to go that route. I do continue to use the OEM filter, and will always do so.
  5. #5
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,205
    Arrow Keep Using "Mazda Full Synthetic 0W-20 Gf-5 With Moly Engine Oil" for oil changes?
    Same here. I plan to use Mazda moly 0W-20 oil and OEM oil filter (not the Value line) for as long as I own the CX-5. And I also DIY for all the maintenance.
  6. #6
    Registered Member
    Join Date
    Apr 2019
    Posts
    6
    Is it the same for the turbo?
  7. #7
    Registered Member
    2019 Mazda CX-5 Signature
    Join Date
    May 2019
    Location
    Belleair Beach, Florida
    Posts
    95
    Quote Originally Posted by dihawk View Post
    Is what the same?
  8. #8
    Gen-1 Kodo Design 👌 ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,317
    No. The turbo uses 5w30 and I don't believe the quart 5w30 bottles offered by Mazda are the high moly versions like the 0w20 is.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 86k miles
    01/2013 build | 4/20/2013 delivery
  9. #9
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,317
    Quote Originally Posted by starfish View Post
    The high moly Mazda 0w20 oil is considered great oil and you should have no qualms continuing to run it.
    I don't run it only because I don't feel it is worth the price premium over a 5qt jug of Castrol Edge, or Pennzoil Platinum, or whatever brand you use. It's at least $20 or more per oil change cost for me over using the other brands. If you can get it at a good deal, then go for it, or if the cost premium doesn't bother you, then keep using it. BITOG, as well as oil analysis reports here have all pointed to the high-moly 0w20 oil being great oil.
Similar Threads
  1. 2014 Mazda 2 engine air filter: which way is "front"?
    By Jeff-TX in forum Mazda2 General
    Last Post: 11-10-2017, 12:00 AM
  2. Replies: 0
    Last Post: 12-05-2014, 02:22 PM
  3. Replies: 2
    Last Post: 05-20-2011, 02:24 PM
  4. Mazda Rotary Engine "Flying Car"
    By Old Rotor in forum Rotary Mazdas
    Last Post: 04-05-2007, 05:08 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
