Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 5 of 5
Thread: P5 Troubling Start and Problems
  1. #1
    Registered Member
    Mazda, Protege5
    Join Date
    Aug 2015
    Location
    US
    Posts
    36
    Hello everyone!,
    Just recently my P5's CEL has came up, got it checked. Came up with codes, P0304, P0102, P0113, P2009, P0660. That was 3 weeks ago. When I would stop at a light the car kept wanting to turn off, like bogging. When leaving for I would start the car, but then It'll die as soon as it tries to idle, sometimes it won't even crank leaving me to think I need a new starter. The CEL would appear and go away, I mean like I'll run the car normal, no problems, no bogging, no stuttering, no stalling. But out of nowhere it will show back up and the car will run extremely rough. It goes on like that, CEL comes and goes but only running rough when CEL is on. Also it's has touble sta The things is that I did all I had to do related to the codes, cleaned the MAF. Replaced all wires, coils, and spark plugs. The problem still persists. I don't know what to do anymore. So I came here for some guidance. 👌🤝
    Here's with CEL and problems starting.
    https://youtu.be/alyRac9HJN8
    Here's without CEL (Seconds after recording 1st vid)
    https://youtu.be/EwOOTSai02M
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,373
    The P0660 is for your VICS solenoid valve.
    It has most likely failed (it's quite common)
    The P2009 is for "intake runner voltage low" which is referring to either the VICS or the VTCS and that may mean both your solenoids have crapped out. (The factory service manual doesn't have code P2009, it uses another number.)
    If replacing the solenoid valve (or valves) doesn't fix your problem then consider cleaning or replacing the EGR and IAC.
    The Diagram Dude
  3. #3
    2008.5 MGM MS3 rsvinylgraphics's Avatar
    Donated: $5
    Join Date
    Oct 2009
    Location
    Indiana
    Posts
    1,190
    The p0304 code is cylinder 4 misfire. Since you said you replaced the coils, wires and plugs it might be a dirty or faulty fuel injector on cylinder 4.
    The p0102 is the mafs, since you said you cleaned it and it didnt help you probably need to replace it.
  4. #4
    Registered Member
    2010 Mazda 5 Sport
    Join Date
    May 2019
    Posts
    96
    Why do I smell a bad battery/charging system? You said it won't crank some times? Then there is very little juice in the battery for whatever reason. This will cause a thousand electrical gremlins. Cars running on a very weak charging system will exhibit everything you have mentioned. Bogging...no starts...hard starts...low voltage codes...miss fires.
    I for one, would get the battery AND alternator tested at your local parts store. Rule that out.
  5. #5
    Registered Member
    2003 Mazda protoge 5
    Join Date
    Aug 2019
    Location
    Tacoma Washington
    Posts
    51
    Right above, THIS, this could be the root of your ailments and this is because your car has computers to manage the engine (Engine Control Unit), body (body control unit) and so on and they utilize sensors and all of them need at minimum, 12V to run and then generate a 5V reference signal to control the various sensors (or simply to read their parameters) to control the motor's air/fuel mixture among other things. If either the 12V main voltage or 5V reference, or both are down, you'll get codes, but at that point, you should see something for the charging system too, a sign that it's not working right.
    Get that checked, or better yet, grab your Volt/Ohm meter and test at the battery terminals what your battery reads when not running then start the car and get it to idle and then see what you see at the battery, if UNDER 12V at idle, it'll not be fully charging, leaving your poor battery at a subcharged state. To charge, the battery needs to see between 13 and 14V to cover for usage by accessories etc while running.
    I just spent almost 2 months getting my car back to health and it turned out to be the timing was apparently a tad off, not enough to keep it from running, but enough to have it running like poo when at idle and then stall out etc. However, an install of the water pump fixed that as I this time made double sure the timing was absolutely spot on and the MAF sensor was swapped out for the old one (the new one appears to have gone faulty) and now see everything as active when viewing on my OBD II reader's live data and has been running fine for about a month now. The reason, being lead down various false paths along the way and the point here is, if you get a bunch of codes and the batter acts like it's barely turning the starter at times, it's a clue something is up with the charging system. I had that issue a couple of years back and it was the alternator not producing enough of a charge to keep the battery fully charge and would periodically run down to where it could not spin the starter. The diode appeared to be the issue. My buddy has just put in (actually I did it) in a 1984 Rabbit yesterday, new from Rock Auto and it's not fully charging, according the hired help at the local Autozone. I need to drop by to get my parka I left there yesterday and I'll take my volt/ohm meter to check and some contact cleaner as the connector on the back of the alternator has the green fuzzies on all three connections and then see what it does.
    Also, check your connections to the back of the alternator, battery and starter for good connections and grounds as a bad ground for example will pull your power down to where you get a too big of a voltage drop to adequately charge the battery.
    Good luck!
Similar Threads
  1. First Start Oil Leak / Problems
    By chris.mp5 in forum Protege5
    Last Post: 11-30-2014, 04:17 PM
  2. Problems with my cx7 remote start
    By Jordanmc in forum Mazda CX-7
    Last Post: 10-15-2013, 06:16 PM
  3. remote start problems
    By shrexster in forum Mazda CX-7
    Last Post: 12-02-2006, 05:33 PM
  4. Start-up Problems
    By Mazda Sales in forum Mazdaspeed3
    Last Post: 07-03-2004, 05:46 PM
  5. Troubling things...1/4 mile predictions
    By Darin in forum Pics & Builds
    Last Post: 08-25-2003, 11:50 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
