Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 33
Thread: How are reverse backing up sensors supposed to operate?
  1. #16
    Registered Member
    2018 Mazda CX-5 AWD Grand Touring
    Join Date
    Sep 2019
    Posts
    28
    Just an update, I took it to the dealership and the sensors are indeed not working correctly. However, there is a posted TSB about the issue "Some vehicles may exhibit the rear parking sensor beeping without any obstacles behind it when the shift lever is shifted into Reverse."
    He showed me the repair procedure, they basically have to back-track all the cabling for the rear sensors along the entire car to pinpoint the wire interference causing the problem. It's a wiring interference problem. It's very involved, can take 4-5 hours to diagnose, they have to remove panels and parts and the dashboard on the car to gain access to the wiring, it's very complex to diagnose where the problem is in the wiring and then fix it. My dealership has never encountered this issue before, so it's the first one for them.
    Thankfull it's all under warranty. I just have to drop the car off to them and leave it there a whole day so they can work on it, which I scheduled for Tuesday, so I'll chime in back in once it's fixed to confirm what exactly was causing it for ya'll for future reference.
  2. #17
    Registered Member
    2019 CX-5 Reserve Eternal Blue
    Join Date
    Aug 2018
    Location
    Central Virginia, USA...the winding rural part
    Posts
    1,325
    That's interesting.
    I wonder what type of signal is being sent from the sensors that is subject to interference?
    And it sounds like the interference can come from lots of sources, not just a specific frequency or type.
    Maybe needs shielded cable.
  3. #18
    Registered Member
    Join Date
    Mar 2019
    Posts
    40
    If it were me, I would not have it repaired. You just hope the dash and panels are reinstalled so you don't develop rattles and strange noises. The sensor is nice but just use your mirror.
  4. #19
    Registered Member
    2019 CX-5 Signature
    Join Date
    Dec 2018
    Location
    IL
    Posts
    462
    Quote Originally Posted by CX_FIVER View Post
    OP's referring to back-up sensors, not blind-spot.
  5. #20
    Registered Member
    Join Date
    Mar 2019
    Posts
    40
    Quote Originally Posted by Sig cx-5 View Post
    I understand. I was referring to when the OP backs up, use the mirror. I have used the mirror to back up for decades and still use the mirror until the sensor beeps. It is nice to hear the beep and stop but, to me, not worth having the dash removed.
  6. #21
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,196
    Arrow How are reverse backing up sensors supposed to operate?
    The problem for OP's rear parking sensors is they beep continuously whenever he shifts the gear to reverse. This is very annoying and he definitely has strong desire to get them fixed.
  7. #22
    Registered Member
    Join Date
    Mar 2019
    Posts
    40
    Quote Originally Posted by yrwei52 View Post
    I wonder if the OP turned it off if that would disconnect it? I assume it would.
  8. #23
    Harpy Eagle Chocolate's Avatar
    2019 Mazda CX-5 AWD
    Join Date
    Aug 2019
    Posts
    276
    Interesting strategy, but it's covered under warranty and presumably the next buyer wants them to work.
  9. #24
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,196
    It seems OP's rear parking sensors are Mazda's genuine accessory which is like a third-party add-on unit. There's a physical switch usually installed in the trunk area. Yeah OP can turn his annoying malfunctioned rear parking sensors off easily if he can find that on-off switch.
  10. #25
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,325
    I don't understand. I've not heard of a Mazda Genuine Accessory.
    Are you saying this is an aftermarket thing different from a factory installed (port/dealer) function that has the On/Off switch in the dash?
  11. #26
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,196
    Quote Originally Posted by Avoidin Deer View Post
    Mazda factory Front and Rear Parking Sensors are only now available on 2019 CX-5 Signature although they've been available in other regions for many years. The factory Front and Rear Parking Sensors are integrated with Back-Up Camera and Infotainment System. But those Rear-only Parking Sensors are available as Mazda genuine accessory and it's an independent system which is not integrated with Back-Up Camera and Infotainment System. It's like aftermarket parking sensors which can only beeps. OP has a 2018 CX-5, so his Rear Parking Sensors listed on window sticker have to be a Mazda genuine accessory. But this Rear Parking Sensors as the accessory are totally different from factory Front and Rear Parking Sensors.
    Here're true factory integrated Front and Rear Parking Sensors and Back-up Camera. The rear parking sensors incorporate with back-up camera on the same screen. The infotainment screen can also display front parking sensors with graph too! Notice even the Back-up Camera function is more sophisticated than ours as it features not only a static blue guideline like us, but also an additional dynamic yellow "predicted" guideline depending on your steering wheel angle!
    Quote Originally Posted by Anchorman View Post
    The front sensors are integrated into the rear camera so it generates an image of the front and back sensors on the screen that drops out at about 3mph. Cars with HID headlights must have headlamp washers but not LEDs, don't ask me why!
    The parking sensors show up on the rear camera screen too but no headlight washers and no rear camera washer as you can see!
    The front sensors come on automatically immediately after having reversed OR they can be manually operated from a button on the dash. When you drive off they go off at about 5mph or you can push the switch again.
  12. #27
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,325
    Interesting.
    Again, being new to the brand, I had no idea 2019 was the first year for those.
    As always, thanks for the detailed feedback.
    So much to learn...
  13. #28
    2019 Mazda CX-5 AWD
    Join Date
    Aug 2019
    Posts
    276
    The omission of this feature (across all trim lines) is inexplicable. The backup camera itself is adequate, but low resolution. An area Mazda could improve for sure.
  14. #29
    Registered Member
    Join Date
    Sep 2019
    Posts
    28
    Ok, situation is more complex than originally thought. Let me see if I can summarize this short and to the point.
    My car has the accessory package rear parking sensors, these were installed after the car was manufacturered, at the dealership when it was brand new.
    This rear parking sensor kit package is different than if the rear parking sensors were installed during manufacturing. If they were installed during manufacturing the module would be in a different place, and the wiring would span the length of the car, and the TSB would apply to this type of installation for the fix where they have to track down the wiring interference.
    However, because I have the accessory package installed after manufacturing the package is installed differently. The module and wiring is all in the back. Because of this style of installation the likely cause of the problem is a faulty module. This accesory package does have a warranty period, but mine is already past warranty, it's shorter warranty than the car because it's an accessory part.
    With this accessory package you cannot just buy specific components, you have to purchase the entire accessory package and re-install it all. That means $600 for me to purchase it, and then have the new stuff replace the old stuff. There just isn't any other option.
    So, we decided to just leave it all alone as is. While we could have had it disconnected we were worried the rear cross traffic alert would also then be disabled since it uses the same sensors, which work fine, the sensors are fine, it's just the module. That feature of the car works just fine, so I didn't want to deactivate it and lose it. Therefore, we decided to just leave it all as is. The beeping only happens in reverse, and all it means is my rear parking sensors won't work right, but the rear cross traffic alert still will.
    In summary, the problem can be fixed, but it will cost me over $600 to do so therefore I opted to leave it alone for now. If I ever have extra cash in the future I can have the module replace. Right now, it just isn't that big of a deal, and it does not annoy me in any way. It's not like I drive the car in reverse. So not a big deal really, and the option is there in the future if I ever want to fix it if I have extra cash I want to burn.
    Cliff Notes:
    Because it's an accessory package the rear parking sensors are installed in a different way, and to fix the issue requires buying a new accessory package so the module can be replaced, which would cost a lot of money cause the parts are out of warranty at this time. I decided to leave it alone for now.
  15. #30
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,325
    1-So the rear cross traffic alert beeps differently if a car is coming?
    2-Did they give you a quote to replace the unit? I asume the $600 does not include labor.
    3-A silly question...is the cross traffic alert also a Mazda accessory and not a factory option? That kinda makes no sense to me that they use the same sensors, because my cross traffic alert uses the Blind Spot Monitoring sensors, and I don't have rear parking sensors.
    (What a goat rodeo.)
Similar Threads
  1. Amazing deal on reverse sensors
    By Robotaz in forum Mazda5 Infotainment
    Last Post: 08-24-2012, 12:12 PM
  2. front/rear reverse sensors (aus)
    By desssa in forum CX-5 Infotainment
    Last Post: 05-26-2012, 07:32 PM
  3. How do the fans operate with A/C on?
    By bernardphoto in forum Other Mazdas
    Last Post: 08-03-2009, 02:52 PM
  4. Cooling Fans - When should they operate?
    By altaski in forum Mazda CX-7
    Last Post: 04-29-2009, 12:06 PM
  5. no reverse lights when backing up
    By tallrd in forum Mazdaspeed Protege
    Last Post: 04-06-2005, 10:09 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
