Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: How are reverse backing up sensors supposed to operate?
  1. #1
    Registered Member
    2018 Mazda CX-5 AWD Grand Touring
    Join Date
    Sep 2019
    Posts
    28
    On my 2018 CX-5 GT I think I have the reverse parking/backing up sensors, but wondering if they are operating normally, I've never had that feature before.
    When I put my car into reverse, it goes "beep, beep, beep, beep, beep" while I backup, even if nothing is behind me. I haven't tried to backup toward a solid object yet to see if the beeping changes.
    Is that normal for it to beep when nothing is behind you? And what should I expect when I do backup with an object behind me?
    Thanks
  2. #2
    Registered Member
    2019 CX-5 Signature
    Join Date
    Dec 2018
    Location
    IL
    Posts
    463
    Quote Originally Posted by BrentJustice View Post
    Thanks
    No, that is not normal. Now, on our's, that also has the front sensors, it will beep in reverse if there is an object in the front of the vehicle. To me that's odd, as my Lexus does not do that.
  3. #3
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,198
    Arrow How are reverse backing up sensors supposed to operate?
    Thanks
    Firstly, your 2018 CX-5 GT doesn’t have rear parking sensors from factory. Yours is an add-on accessory or an aftermarket unit if you really have one. Verify it by checking if you have 2 small round sensors on your rear bumper.
    Like Sig cx-5 said, the rear (or front) parking sensors should not act the way your described. It beeps only when there’s an object near the bumper. Take the CX-5 back to your Mazda dealer for warranty service.
  4. #4
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,198
    By the way, there*s an aftermarket device which is simply beeping whenever you shift the gear to reverse to warn the people near by. But that*s a loud beep.
  5. #5
    Registered Member
    Join Date
    Sep 2019
    Posts
    28
    I looked at my car's window sheet and it says it has "Parking Sensors." I also looked at the back of my car and there are 4 rear sensor dots. The sound I hear is only on the inside.
    I recorded a video of what it sounds like in reverse, remember, this is with nothing behind me, and it happens everytime I put the car in reverse, even in an empty parking lot, everywhere I'm at.Is this normal?
    https://youtu.be/YMiPpvYQyXc
  6. #6
    Registered Member
    2019 CX-5 Reserve Eternal Blue
    Join Date
    Aug 2018
    Location
    Central Virginia, USA...the winding rural part
    Posts
    1,334
    Just to clarify, rear parking sensors are not standard equipment on the 2018 CX-5 Grand Touring, but they are a Mazda add on accessory you order with the car, just like roof rails and hitches. They are installed by Mazda (not sure if at the factory, at the port, or by the dealer).
    As has been stated, the behaviour you describe is not normal.
  7. #7
    Registered Member
    Join Date
    Sep 2019
    Posts
    28
    Right, I absolutely understand that. I purchased the car used, not new.
    So in the video I provided, I'm trying to determine if those are the rear parking sensors, and if they are operating correctly?
    My car's window sticker has "Parking Sensors" on it, I have 4 sensor dots on the back, and that's the sound I hear in reverse even with nothing behind me, or moving, it does that sitting still in reverse.
  8. #8
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    State of Jefferson - SO Oregon
    Posts
    2,519
    Yup, it's broke.
    Dealer can fix it.
  9. #9
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,198
    If “Parking Sensors, Rear“ is listed within your true factory window sticker, yours was installed at the port as a Mazda genuine accessory. The item is included in 3-year / 36K-mile new car warranty. Take your CX-5 to your Mazda dealer to fix this parking sensor problem as yours is not normal.
  10. #10
    Registered Member
    Join Date
    Sep 2019
    Posts
    28
    Thank you all so much for the feedback and help. I'll schedule an appointment with the dealer.
  11. #11
    Registered Member
    CX-5 AWD, 2017
    Join Date
    Aug 2017
    Location
    Sweden
    Posts
    212
    Quote Originally Posted by Sig cx-5 View Post
    This is actually a good feature that your front sensors are also active (along with the reverse sensors) when you are reversing in to a garage and turning at the same time, trying to avoid a fence in front of the garage. While you are concentrated in the rear of the car you might hit the fence or tree or wall or whatever that lies in front of the car. If it is a straight back up in to the garage, then there is less of that problem.
  12. #12
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,306
  13. #13
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    531
    In your video I see a car behind you. I guess you also tried it with nothing behind you too, and it still beeps.
  14. #14
    Registered Member
    Join Date
    Sep 2019
    Posts
    28
    Correct, it does that every single time I backup no matter where I'm at, always does it, with nothing behind me... that car was off to the left in the video, not behind the car... but yeah, all the time it does it
  15. #15
    Harpy Eagle Chocolate's Avatar
    2019 Mazda CX-5 AWD
    Join Date
    Aug 2019
    Posts
    283
    It only takes one bad ultrasonic sensor out of the 4 to trigger a warning sound. Luckily it is covered under warranty.
Similar Threads
  1. Amazing deal on reverse sensors
    By Robotaz in forum Mazda5 Infotainment
    Last Post: 08-24-2012, 12:12 PM
  2. front/rear reverse sensors (aus)
    By desssa in forum CX-5 Infotainment
    Last Post: 05-26-2012, 07:32 PM
  3. How do the fans operate with A/C on?
    By bernardphoto in forum Other Mazdas
    Last Post: 08-03-2009, 02:52 PM
  4. Cooling Fans - When should they operate?
    By altaski in forum Mazda CX-7
    Last Post: 04-29-2009, 12:06 PM
  5. no reverse lights when backing up
    By tallrd in forum Mazdaspeed Protege
    Last Post: 04-06-2005, 10:09 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
