Made in USA and Free Shipping on all orders shipped inside the US.
Results 1 to 2 of 2
Thread: Stabilizer bar, bar link, bushings questions
  1. #1
    Registered Member
    2002 Mazda Protege5
    Join Date
    Dec 2013
    Location
    Bowling Green, KY
    Posts
    80
    Cool Stabilizer bar, bar link, bushings questions
    Hey Everyone,
    This weekends car project entails replacing both rear strut assembly units because the rear passenger strut mount is completely shot. Mechanic wanted to charge $1000 to get the job done so it looks like I am teaching myself something new instead. I ordered two Monroe rear struts from RockAuto (271589, 271588). I'll replace both and then take the car somewhere to get a tire alignment.
    I was looking into replacing at least the stabilizer bar end links but I am confused as to which mm lengths to choose from.. Some are 187mm long and others 220mm from RockAuto. Which is the standard length?
    This also appears to be the case with the bushings too. Some are 22mm diameter and some are 23mm diameter. I guess you have to know the diameter of your stabilizer bar but assuming mine is oem stock, which diameter would I choose for the bushings?
  2. #2
    Registered Member
    2003 protege 5
    Join Date
    Jul 2011
    Location
    so cal
    Posts
    96
    You want the shorter links and I believe the stock rear bar is 16mm. Msp is 19mm. Awr is 21mm and progress is 22mm.
Similar Threads
  1. Front Stabilizer Link
    By sbaxter in forum Mazda5 Wheels, Tires, Brakes & Suspension
    Last Post: 05-12-2015, 04:57 PM
  2. How to change front struts and stabilizer link/bushings??
    By wendy93089 in forum Mazda5 Wheels, Tires, Brakes & Suspension
    Last Post: 03-21-2014, 11:01 AM
  3. Replies: 0
    Last Post: 09-13-2010, 08:34 PM
  4. WTB Suspension rod stabilizer link
    By tillyspeed81 in forum Completed Transactions
    Last Post: 04-19-2009, 06:13 AM
  5. Stabilizer end link removal
    By RatLabGuy in forum Protege5
    Last Post: 02-25-2009, 01:38 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
