CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 8 of 8
Thread: Exhaust Question for Cali SF Bay P5's.
  1. #1
    Registered Member
    2002 P5
    Join Date
    Aug 2019
    Location
    SF Bay Area
    Posts
    4
    How do you guys have your manifold / downpipe set up and still pass smog?
    I've read other threads and have seen a lot of combinations about which header is mated to which downpipe, but I didn't see anything that was specific to CA. I'm not looking for make MAD GAINZ, just a couple extra ponies in the bottom end. Already have the washable K&N in the filter box.
    Any input or suggestions would be appreciated!
  2. #2
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    618
    Well in all honesty, getting torque your going to need a 4-2-1 which they don't make anymore. You can do the 626 trick and weld that up. Also you would want to pair that up with a Cold Air Intake and the Mazda protege3 ECU. Then you will have a fun little car. But then that only gets you small gains, and having to pass California smog it's not worth it because you need a o2 sensor extension. You won't pass visual inspection. Just turbo it from the Mazdaspeed and be done with small gains.
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,373
    Some guys put on what's needed to pass the smog test then put their headers and such back on.
    Every year.
    The Diagram Dude
  4. #4
    Registered Member Anzi's Avatar
    2002 Protegé5 manual
    Join Date
    Feb 2018
    Location
    SF Bay Area, California
    Posts
    139
    Quote Originally Posted by UND34D View Post
    I just have the stock manifold, precat, downpipe, and cat. With an MP3 ECU and a catback, I make a decent amount of power above stock
  5. #5
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    400
    Quote Originally Posted by pcb View Post
    Every year.
    Yes they do. I know some guys in Missouri that used to do the same thing. Seems like an awful lot of hassle to me...
  6. #6
    Swollen Member Natey's Avatar
    Donated: $40
    Mazda
    Join Date
    Jan 2003
    Location
    Pleasure Point, California
    Posts
    6,506
    The answer was to find a shady smog guy, but now the answer is is Trump. From what I've read in today's paper, he is abolishing California smog laws. We'll be just like the other 48 now. Dust off those turbo kits!!
    Increasing airflow and decreasing back pressure will not give you any ponies at the bottom end, though. Mayyybe 3 or 4 above 5500 rpm, but you'll be losing torque.
    NPOT (Norcal Protege Options Team)
    http://www.cardomain.com/ride/335883...photo-gallery/
  7. #7
    Registered Member Saudade's Avatar
    2003 P5
    Join Date
    Nov 2018
    Location
    SoCal
    Posts
    6
    Yep, ours is stock. If you want to mess with the exhaust from the cat forward, you need to find CARB compliant parts and keep the receipts and other paper work. Also Cold air intakes are no go if not CARB compliant. You'll fail smog with a "TAMPERED" status.
    Unless you live in a county that does not require smog checks for renewals. You can check your zip code here:
    https://smogcheck.ca.gov/pubwebquery...ZipLookup.aspx
    2003 Protege5, Auto. Approx 224k
  8. #8
    Registered Member
    2002 P5
    Join Date
    Aug 2019
    Location
    SF Bay Area
    Posts
    4
    Thanks for the responses, guys.
    The MP3 ECU swap, how does that come up with your smog checks?
Similar Threads
  1. Hi from Cali
    By SkyActiv in forum Mazda3 General
    Last Post: 12-03-2011, 11:47 PM
  2. Cali ecu
    By MSP507 in forum Completed Transactions
    Last Post: 06-09-2010, 07:20 PM
  3. Going to Cali...
    By Driver_X in forum Global
    Last Post: 10-28-2007, 02:08 PM
  4. Off to Cali...
    By hawaiian_msp in forum Global
    Last Post: 04-09-2005, 04:33 PM
  5. anyone in cali help!
    By RoTi speed in forum Global
    Last Post: 10-15-2003, 10:10 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
