Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: ACC Operation
  1. #1
    Pitter Pitter's Avatar
    Donated: $25
    2020 CX-5 Signature Azul Metalico
    Join Date
    Aug 2019
    Location
    Cali, Colombia
    Posts
    225
    ACC Operation
    How do you turn the vehicle on to ACC i.e. where the engine is off but you can operate the radio and power windows?
  2. #2
    Registered Member
    2019 CX-5 Reserve Eternal Blue
    Join Date
    Aug 2018
    Location
    Central Virginia, USA...the winding rural part
    Posts
    1,328
    Push the Start Button without pressing the brake (assuming you got the fob on you).
    Here's the whole set of instructions, Pg 4-4 in the North American manual:
    The system operates only when the key is within operational range. Each time the push button start is pressed, the ignition switches in the order of off, ACC, and ON. Pressing the push button start again from ON switches the ignition off.
    The engine starts by pressing the push button start while depressing the clutch pedal (manual transaxle) or the brake pedal (automatic transaxle). To switch the ignition position, press the push button start without depressing the pedal.
    Do not leave the ignition switched ON while the engine is not running. Doing so could result in the battery going dead. If the ignition is left in ACC (For automatic transaxle, the selector lever is in the P position, and the ignition is in ACC), the ignition switches off automatically after about 25 minutes.
    The power supply to electrical devices turns off and the push button start indicator light (amber) also turns off.
    WARNING Before leaving the driver's seat, always switch the ignition off, set the parking brake, and make sure the selector lever is in P (automatic transaxle) position or in 1st gear or R (manual transaxle): Leaving the driver's seat without switching the ignition off, setting the parking brake, and shifting the selector lever to P (automatic transaxle) position or to 1st gear or R (manual transaxle) is dangerous. Unexpected vehicle movement could occur which could result in an accident. In addition, if your intention is to leave the vehicle for even a short period, it is important to switch the ignition off, as leaving it in another position will disable some of the vehicle's security systems and run the battery down. ACC (Accessory) Some electrical accessories will operate and the indicator light (amber) illuminates. NOTE The keyless entry system does not function while the push button start has been pressed to ACC, and the doors will not lock/unlock even if they have been locked manually.
    When Driving Start/Stop Engine
    ON This is the normal running position after the engine is started. The indicator light (amber) turns off. (The indicator light (amber) illuminates when the ignition is switched ON and the engine is not running.) Some indicator lights/warning lights should be inspected before the engine is started (page 4-12). NOTE When the push button start is pressed to ON, the sound of the fuel pump motor operating near the fuel tank can be heard. This does not indicate an abnormality.
  3. #3
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    State of Jefferson - SO Oregon
    Posts
    2,518
    And to switch directly to ACC when turning the ignition off, put it in park and hold the transmission interlock button while you hit the ignition button.
  4. #4
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,328
    Quote Originally Posted by shadonoz View Post
    ^^This is a handy tip^^
    I've used it a lot since Shadonoz put it out there.
    You may have noticed that--unlike many other cars--when you turn off the ignition, everything in the CX-5 turns off...including the radio. (My truck would keep playing tunes until I opened the door.)
    So by following this tip, you can arrive at your destination and finish listening to a song without having to leave the engine running.
  5. #5
    Registered Member
    2019 CX-5 Signature
    Join Date
    Apr 2019
    Posts
    63
    That's a handy tip. How did you discover this? I don't think it's in the manual.
  6. #6
    Donated: $25
    Join Date
    Aug 2019
    Location
    Cali, Colombia
    Posts
    225
    Very good, thank you.
  7. #7
    Registered Member Conrad 16.5's Avatar
    2016.5 CX-5 Grand Touring AWD titanium/black
    Join Date
    Sep 2016
    Location
    Northern Illinois
    Posts
    973
    Doesn't anyone know why Mazda, in all their wisdom, neglected to include RAP (retained accessory power) in their cars? Without exception, every car that I have ever owned had RAP which allowed the windows, sunroof, and the radio to still operate after the car had been shut down. I can't tell you how many times I've had to turn the power back on just so that I could close the windows in my CX. It's just stupid.
    "And to switch directly to ACC when turning the ignition off, put it in park and hold the transmission interlock button while you hit the ignition button. "
    The above does work but it doesn't power the windows or sunroof and it shuts down after a short period of time.
    I discovered that if you turn the car on, but don't start it, then place the gear selector in neutral, then press the Start button, the power will stay on for hours. This is a danger because you can drain the battery so be careful.
    "Don't bother me with facts, Son. I've already made up my mind." -Foghorn Leghorn
  8. #8
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,328
    Quote Originally Posted by Conrad 16.5 View Post
    It is weird that for all the high-end accoutrements, handling, etc. that Mazda has created, for some reason they fall apart when it comes to implementing User-Interface firmware that's been around since the 90s. The RAP issue, the sketchy Infotainment performance...it makes no sense.
  9. #9
    Registered Member
    2018 CX-5 Touring
    Join Date
    Feb 2010
    Location
    CT
    Posts
    192
    On my 2018 the windows will close after turn off.
  10. #10
    Registered Member
    2019 CX-5 Reserve
    Join Date
    May 2015
    Location
    South Florida
    Posts
    92
    Quote Originally Posted by Martyd View Post
    They would do it on my 2106 GT also, but I think only as long as you didn*t open the door first.
  11. #11
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    Posts
    2,518
    Quote Originally Posted by dwill View Post
    Works on 16 and 18 but not on my 17. Why some and not others?
  12. #12
    Registered Member
    2019 CX-5 Signature Soul Red Crystal
    Join Date
    Aug 2019
    Posts
    40
    What is the transmission interlock button?
  13. #13
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    Posts
    2,518
    Quote Originally Posted by Googleplex View Post
    Knowing it's an interlock switch, I just experimented. Science!!!
    Or maybe I read it somewhere. Can't remember. Can't even remember what I had for breakfast!
  14. #14
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    Posts
    2,518
    Quote Originally Posted by mutualcore View Post
    That big button you squeeze to get it in and out of Park.
  15. #15
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,328
    That's how my truck was. You tun off the ignition and it went into a version of Accessories mode until you opened the door as though you were exiting...then all power was cut off. This was with a physical key in the ignition switch.
    I've not tried this in my 2019 CX-5, since I usually drive with the A/C on, the windows up and the sunroof closed (just trying to keep the country dust out). All I know is that the Infotainment turns off when I turn off the engine.
Similar Threads
  1. Sunroof operation
    By KBrian in forum Mazda5 Accessories & Appearance
    Last Post: 06-16-2010, 03:09 AM
  2. DSC effect on AWD operation (spd 6)
    By pmh67 in forum Mazda6 Engine & Transmission
    Last Post: 01-12-2010, 12:19 AM
  3. Operation Questions
    By JJShantell in forum Mazda5 General
    Last Post: 11-04-2007, 07:01 AM
  4. LSD Operation
    By JDM Sam in forum Mazdaspeed Protege
    Last Post: 11-19-2006, 11:39 PM
  5. Operation LARK
    By REMillers in forum Lounge
    Last Post: 01-06-2005, 01:29 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
