Results 1 to 5 of 5
Thread: 2012 CX9 with 75k Miles - Too Late to Switch to Synthetic Oil?
  1. #1
    Registered Member
    2016 Mazda CX-5 GT
    Join Date
    Jul 2015
    Location
    NJ
    Posts
    16
    Hello, All. Has my CX9 since brand new in 2012 and always used conventional 5W-20. Picked up some oil at Wal Mart the other day and noticed the synthetics are almost the same price as conventional these days. Id like to switch, but Ive read some older cars that have always used conventional may exhibit leaks if switching to synthetic. But having 75k miles - do you think its too old to switch or should I give it a shot?
    Thanks for your opinion!
  2. #2
    Registered Member
    Mazda CX-9 Grand Touring 2016
    Join Date
    Sep 2016
    Location
    Washington, the state
    Posts
    538
    It will be no problem to switch to synthetic engine oil or to switch back to conventional oil. There's a lot of misinformation out there.
  3. #3
    Registered Member Bronco Boy's Avatar
    2009 Mazda CX-9 GT
    Join Date
    Aug 2019
    Location
    Coquitlam,BC,Canada
    Posts
    60
    Never too late for synthetic, unless you have leaks.
  4. #4
    Registered Member
    2016 Mazda CX-5 GT
    Join Date
    Jul 2015
    Location
    NJ
    Posts
    16
    Thanks, boys!
  5. #5
    Biggie T Skinny helbigtw's Avatar
    CX-3, CX-5 & CX-9 Moderator
    08 CX-9 GT Fwd, Bose/Nav, BSM,Compass/Homelink, Pwr Lift,Tow
    Join Date
    Feb 2011
    Location
    Pittsburgh, PA
    Posts
    2,133
    Do It! 103k on mine and I still use it. I run 5w30 most of the time Mobil 1 full synth (not the extended 15,000 mile stuff, don't buy that) and Mobil 1 filter, oil & filter change every 5k or 1 year. 5/20 is thinner better gas mileage and a little more power, but 5/30 will protect the motor better and also does not use nearly as much oil. Since day 1 my CX-9 would use tons of 5/20, somewhere in the ballpark of two to three quarts every 5,000 miles. With the Mobil 1 5/30, it only uses somewhere around a quart and a half every 5000.
Similar Threads
  1. Replies: 15
    Last Post: 09-02-2017, 01:23 AM
  2. Replies: 2
    Last Post: 01-17-2016, 02:11 PM
  3. Replies: 5
    Last Post: 02-05-2009, 09:15 PM
  4. Switch to synthetic oil?
    By Chaotic Bliss in forum Protege5
    Last Post: 10-31-2006, 10:18 AM
  5. Can I switch over to synthetic?
    By kmfdMZ3 in forum Mazdaspeed3
    Last Post: 03-11-2006, 01:25 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
