Results 1 to 5 of 5
Thread: 2013 CX-5 - rear dampers leaking after 21k miles
  1. #1
    Registered Member
    BMW E92 M3 & CX-5 AWD Sport Nav 175PS stormy blue with stone
    Join Date
    May 2013
    Location
    UK
    Posts
    107
    Hi,
    I just had the annual MOT (mandatory safety inspection in the UK) and it was pointed out to me that both rear dampers have a light misting of oil - not a failure as the damping was within spec. The car (2013 2.2D AWD) has only done 21k miles of mostly gentle driving - all mine. A couple of journeys with the boot full of suitcases.
    The agent said I was the second CX5 this month with the same issue, the other car had only 11k miles!
    Anyone else experienced leaking shocks at such low mileage?
    I've always thought the damping was crap anyway from new - as in it didn't damp much at all and was hopeless dealing with bumps and pot holes.
  2. #2
    Registered Member
    2019 CX-5 Signature; 2014 CX-9 Touring AWD
    Join Date
    Jun 2014
    Location
    Michigan
    Posts
    351
    Alternate headline:
    Rear dampers leaking after six (seven?) years of intermittent, extremely light use.
    Itís not the distance, itís the time.
  3. #3
    Registered Member
    Join Date
    May 2013
    Location
    UK
    Posts
    107
    I guess given the lack of responses, misting on the rear dampers on my car and those of another owner must be isolated issues. When I replace them I won't go with OE parts and try and find a damper that does what it supposed to do.
    If anyone has any recommendations of after market dampers that 'damp' better and control the ride better than stock - feel free to post.
  4. #4
    Registered Member
    Join Date
    Aug 2019
    Posts
    40
    Hmmmm? I would consider any of the "name brand" dampers...Koni, KYB, Bilstein, etc.
  5. #5
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,885
    Most manufactures don't consider them leaking if they only have a oil film on 1/2 of them. Ed
Similar Threads
  1. Drive Belt tensioner leaking at 40,700 miles per dealer
    By txt990 in forum CX-5 Engine & Transmission
    Last Post: 08-19-2019, 02:44 AM
  2. FS: 2013 CWP MS3 in Southern CA, 55k miles
    By mswscco in forum Mazda3 For Sale
    Last Post: 10-08-2017, 06:19 PM
  3. Rear end links and dampers story
    By 5DIY in forum Mazda5 Wheels, Tires, Brakes & Suspension
    Last Post: 05-29-2016, 09:58 PM
  4. @ 90K miles on my 2013 CX-5 and need to replace the brakes/rotors
    By kendotone in forum CX-5 Wheels, Tires, Brakes & Suspension
    Last Post: 03-19-2015, 12:26 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
