Page 5 of 5 FirstFirst ... 345
Results 61 to 74 of 74
Thread: Must have CX-5 Tools and Items
  1. #61
    Registered Member Chocolate's Avatar
    2019 Mazda CX-5 Sport AWD
    Join Date
    Aug 2019
    Posts
    118
    Quote Originally Posted by murky View Post
    I got some for my 2018. They work well, I'd forgotten they weren't stock.
    I put them in using existing holes.
    Thanks, mine are coming Sunday. I think these are well worth 25 bucks.
  2. #62
    Registered Member
    2014 Mazda CX-5 GT AWD w/Tech
    Join Date
    Aug 2013
    Location
    Bloomington, Minnesota, USA
    Posts
    585
    Love Mine!
    Quote Originally Posted by CX-5um View Post
    https://www.youtube.com/watch?v=MVTp8EpzZ5E
    Added 5 psi per tire in a matter of seconds yesterday. Set your psi and it automatically shuts off when reached. Stays planted and does not hop around. No cords to deal with. I also used it to inflate a yoga fitness ball.
    Not a must have but is sure nice to have
    I've had this handy guy for about a year now. It's a wonderful tool and my wife loves it for filling tires on the Burley and on her bike. Well worth the price!
  3. #63
    Old and OCD
    2019 cx5 2006 mx5
    Join Date
    May 2019
    Location
    AZ & A2
    Posts
    5
    Quote Originally Posted by Chocolate View Post
    How did they work out? Any rattles when driving?
    I have a set in my cart on Amazon.
  4. #64
    Join Date
    Aug 2019
    Posts
    118
    Got 'em yesterday, haven't put them on yet. I am satisfied with the quality.
  5. #65
    Registered Member
    2019 CX-5 Reserve Eternal Blue
    Join Date
    Aug 2018
    Location
    Central Virginia, USA...the winding rural part
    Posts
    1,017
    Please let us know how you like them. I have minor doubts because they're so inexpensive, but it seems that most of the buyers are satisfied.
    A couple of buyers said they could not get the pistons to extend, and others recommended you dry-fit the nuts on the bracket stud, since they had issues.
  6. #66
    Join Date
    Aug 2019
    Posts
    118
    I'll grab some pics.
  7. #67
    Join Date
    Aug 2019
    Posts
    118
    Found this installation video.
  8. #68
    Registered Member
    2019 Cx-5 sport
    Join Date
    Apr 2019
    Posts
    64
    thanks for the video....... looks simple enough and seems to work ...
    I wonder when those bottom nuts start getting loose, it might be good to
    have a way to tighten them again before you snap or pull them off that tool...
    I might just try it ..........
  9. #69
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,017
    Quote Originally Posted by joemazdacx5 View Post
    I'm going to order a set, and plan on using LocTite Blue. You can get it at auto stores or home improvement stores, maybe even at Walmart.
    Not sure if you're familiar with the product. Loctite is a "glue" for threaded parts. It comes in different strengths.
    Loctite Red is permanent. Often used for internal engine parts that will never be disassembled.
    Loctite Blue can be undone with moderate force, and it stops threaded parts from vibrating apart.
    Loctite Blue is what I use when I don't want threaded screws to back out, but want to be able to take them apart later. Others here might have better suggestions.
  10. #70
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,249
    Quote Originally Posted by Avoidin Deer View Post
    Watched a youtube vid on changing brake rotors/pads. Dude used loctite blue for the caliper bolts.
    A good lube to have around is Silicone grease. Got a tube at Napa called Sil-Glide or something like that. Used to lube the brake sliding pins. I use lithium grease (with red spray straw) for door hinges at home/car, ect. 2 good lubes to have around not named KY LOL
  11. #71
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,017
    I keep a chart of recommended lubes on my laptop.
    It gets confusing knowing which ones are for what application. Some applications don't mind dirt sticking to it.
    Regarding KY, that conversation belongs in the Dealership Experience threads.
    And those are the nice dealers...they don't all use it.
  12. #72
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,249
    LOL on a serious note though..YES!! Keeping that chart helps. Example: using silicone grease won't harm certain rubber parts/o-rings found on the brake sliding pins. That was a win for me since I used the correct application. What I did wrong was also use it on brake pads hardware clips and backing plate....I should've used something like copper grease. I know better now after doing more research.
    Oh and lithuim grease lubes my car garage hinges and spring.
  13. #73
    Registered Member
    Mazda CX-5
    Join Date
    Dec 2015
    Location
    Chattavegas
    Posts
    373
    Quote Originally Posted by Sig cx-5 View Post
    So, you can't just jack it up from the frame rail like all other modern vehicles?
    *Modern* vehicles cannot be jacked up just anywhere. That applies to mostly pre-1980 cars with a body on frame design. OP is right.
    '06 MX-5 6MT, Custom Sprung Ohlins, Tomei LSD
    '16.5 CX-5 T AWD w/more Soul
    IBA/COG Desmoquattro for pleasure
  14. #74
    Registered Member
    Mazda CX-5
    Join Date
    Dec 2015
    Location
    Chattavegas
    Posts
    373
    so doesn't anyone know if a regular sized tire fits into the spare compartment
    and also be able to close the spare top cover ???
    A CX-7 spare matches better and fits in the spare well. A full size wheel and tire will not with the foam insert in place.
Similar Threads
  1. Eat with your tools
    By altspace in forum Lounge
    Last Post: 08-16-2007, 10:29 AM
  2. Tools
    By TreFlip999 in forum Protege5
    Last Post: 07-21-2007, 04:15 AM
  3. Tools
    By terbow in forum Lounge
    Last Post: 11-13-2005, 06:29 PM
  4. what tools do i need?
    By Rogue in forum Mazda Protege
    Last Post: 10-01-2004, 11:12 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
