Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 107
Thread: Must have CX-5 Tools and Items
  1. #46
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,254
    Quote Originally Posted by Avoidin Deer View Post
    I like that depth gauge. And less than $3!
    Gives accurate thread measurements of all 4 tires let alone different sections of the tire. Lets the owner know exactly how each tire is wearing down. Underrated tool.
  2. #47
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,254
    Oh and I use it to pry off rocks stuck in grooves while down there checking for nails.
  3. #48
    Registered Member
    2019 CX-5 Reserve Eternal Blue
    Join Date
    Aug 2018
    Location
    Central Virginia, USA...the winding rural part
    Posts
    1,055
    Quote Originally Posted by CX-5um View Post
    I'm reading the comments on those at Amazon, and some folks say they are off by 2/32"
    Have you played with yours yet?
  4. #49
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,254
    Hmm...I would check with a measuring tape/ruler when I have the chance. If you had the tool at hand you can see it's easy to check its accuracy.
    That said the measurements may very of the placement on the tire....the sides usually have less depth then the middle.
  5. #50
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    501
    A great tool to have is a magnetic work light like this one: https://www.harborfreight.com/390-lu...ght-63958.html Not that long ago that one was on sale for $19.99. It is a great light. Also a good cordless impact wrench is great to have. https://www.youtube.com/watch?v=RmcdNDkp5Sw Can usually find one cheap on ebay.
  6. #51
    Registered Member Chocolate's Avatar
    2019 Mazda CX-5 Sport AWD
    Join Date
    Aug 2019
    Posts
    135
    Applied dielectric grease on the battery terminals. This really makes a difference in stopping corrosion on the battery. For 7 bucks, a worthwhile preventative maintenance item. On my ES 330, I didn't use it and I saw some major corrosion develop on the battery terminals. I used this on my previous vehicle and it had no corrosion whatsoever 7 years in. You can also use this on many other types of connectors to seal out moisture. Basically, anything that has metal to metal contact, so bulb connectors and other electrical connections. This is also usually sold in smaller packets for a few dollars at the counter at most Auto parts stores such as Advance Auto and Auto Zone.
    Why is dielectric grease better than conductive grease explained (tl:dr: corrosion protection, universal application on all metals) https://www.w8ji.com/dielectric_grea...ive_grease.htm
    The CX-5 does not come with Navigation unless you get the Grand Touring trim (starting MSRP: 31,445) or higher.
    If you have a Sport or Touring trim, you can unlock the navigation functionality with a map card. The Navigation card for the U.S, Canada, and Mexico is part number BHP1-66-EZ1K. It retails for $331.57 from Mazda but the lowest price on Amazon is only 80. (Pretty standard, it's rare that Amazon doesn't have a better price than the dealer on OEM parts). All you have to do is insert the card in the center console and start the car. Then you will have full navigation functionality with voice command, and the voice command system in this car works pretty well. One feature I really like that's unlocked with this card is the infotainment can display the street you're on even when you're on a non-navigation page.
    Demo video (scroll to 0:32):
    Hood Struts
    I cannot believe that a vehicle that pushes $40k in top trim comes with a hood prop rod. The hood is very heavy and could easily break or seriously injure a finger if your hands were to slip while lowering the hood. For about 25 bucks you can install these hood struts from Amazon, which have good reviews. I just ordered these and will update with pics/review once I install them. Here's an image from the reviews in the meantime. This seems like a very worthwhile upgrade.
  7. #52
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson - southern Oregon
    Posts
    2,337
    Quote Originally Posted by Chocolate View Post
    That's great stuff. In the old days we just used petroleum jelly. Worked great, too, but just put it on the outer surface. Dielectric is good inside the connection and out.
  8. #53
    Join Date
    Aug 2019
    Posts
    135
    Quote Originally Posted by shadonoz View Post
    Yeah it really is. I really saw the difference between using it and not using it on those two vehicles. The battery terminals are especially prone to corrosion without it over time.
  9. #54
    Donated: $5
    Join Date
    Oct 2017
    Location
    Posts
    2,337
    I always carry a small fire extinguisher in my cars. Fortunately have never had to use them.
  10. #55
    Registered Member
    2019 Cx-5 sport
    Join Date
    Apr 2019
    Posts
    64
    Do those hood struts fit in existing mounts/holes on the cx5 or did
    you have to use drill ?
    thanks
  11. #56
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,055
    I putzed around and finally bought one for my car a couple of days ago.
    My hesitance was that the max storage temp (120°) is right where most cars get during the summer months. If you live in the south west you can expect to see 160° or higher. Another option is the type that are packaged like flares, and that emits gas that suffocates the fire. The downside is that they're only effective when the wind is not blowing.
    So I stopped beating it to death and bought a Kidde Marine/Auto extinguisher.
    I picked up some safety reflectors at a yard sale a few months ago.
    Regular flares are the last safety item on my list.
  12. #57
    Donated: $5
    Join Date
    Oct 2017
    Location
    Posts
    2,337
    [QUOTE=Avoidin Deer;6659812
    My hesitance was that the max storage temp (120°) is right where most cars get during the summer months. [/QUOTE]
    That would be a concern, but I've never had a problem or heard of anyone having one, have you?
    With fire extinguishers in cars, that is.
  13. #58
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    1,055
    Actually, I've never known anyone who has ever used one of these (successfully or otherwise).
    I'm just stating what the manufacturer's specs are...Max Storage Temp 120°
  14. #59
    Join Date
    Aug 2019
    Posts
    135
    Quote Originally Posted by joemazdacx5 View Post
    thanks
    I haven't received and installed them yet, but it uses existing holes in the hood and engine bay. No drilling/permanent modification required. Looks pretty easy to install based on the reviews.
  15. #60
    Registered Member
    2018 AWD GT Premium Red/Black
    Join Date
    Feb 2017
    Location
    WA
    Posts
    695
    I got some for my 2018. They work well, I'd forgotten they weren't stock.
    I put them in using existing holes.
Similar Threads
  1. Eat with your tools
    By altspace in forum Lounge
    Last Post: 08-16-2007, 10:29 AM
  2. Tools
    By TreFlip999 in forum Protege5
    Last Post: 07-21-2007, 04:15 AM
  3. Tools
    By terbow in forum Lounge
    Last Post: 11-13-2005, 06:29 PM
  4. what tools do i need?
    By Rogue in forum Mazda Protege
    Last Post: 10-01-2004, 11:12 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
