Results 1 to 6 of 6
Thread: Cx5 GT multiple warning lights
  1. #1
    Registered Member
    2014 cx5 grand touring
    Join Date
    Aug 2019
    Location
    Connecticut
    Posts
    2
    A few weeks ago the belt tensioner unit failed while driving. I had that replaced and after that I noticed some hesitation while driving. On Friday I was on the highway and felt more hesitation and when I stepped on the gas I got three error messages. A message engine inspection required, TPMS inspection required, SCBS inspection required. I went to a garage, they checked the oil and said I was low by a couple quarts. They ran the codes and said that the engine was miss firing on all four cylinders. They topped up the oil and the other fluids and reset the codes and sent me on my way. Couple miles down the road the error messages came up again. The car was hesitating and jerking when I was sitting in the parking lot of the garage. Stepping on the gas the car hesitates, gets to about 40 and the hesitation is worse, very little power going up inclines and if I step on the gas too hard the same warning lights come back. The garage told me I need to drive the car so that something in the engine gets re-lubricated. Something (I forgot what they said) was compressed due to low engine oil and that may be why I am having these issues. I*m also overdue for an oil change by about 5000 miles. Car has 125k miles.
  2. #2
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,226
    Quote Originally Posted by Akbinner View Post
    Umm where to start
    .. change your oil.. likely have bad plugs, possibly hastened by dirty oil. Whens the last time you changed your engine air filter, and lastly next time you get a code pulled ask and note what the actual code(s) is for reference. Your engine needs maintenance.. I wouldn't be in a rush to blow it up by trying to push it. Codes will continue to return until the problem is solved.
  3. #3
    Gen-1 Kodo Design 👌 ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,208
    Yikes. First off, change your oil regularly. Depending on your driving conditions a 5k or 7.5k mile oil change interval is acceptable, but I did notice that pushing 7500 and more, I had to add oil. You should check your dipstick periodically. 2 quarts low is pretty unacceptable and a damn good way to blow up your engine.
    I agree with Christopher, check your spark plugs and have the codes pulled...
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 84k miles
    01/2013 build | 4/20/2013 delivery
  4. #4
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    291
    Change the oil first and make sure to use the recommended fully syn 0w20.
    tolerance is minimal on these engines modules and good fresh oil is a must for all the internal elements to function.
  5. #5
    Registered Member
    Join Date
    Aug 2019
    Location
    Connecticut
    Posts
    2
    Thank you for your responses. Garage did oil change and replaced the spark plugs. I learned my lesson ☹️
  6. #6
    Registered Member
    Discovery II, Series
    Join Date
    Feb 2019
    Location
    Mexico
    Posts
    1
    I had that drain plug and the magnet is pretty strong, I cant see ot dislodging from the oil pan. But you are right it sucks that it failed. I got a drain valve for my new car Ill skip the magnets.
    BALDOR MOTION PRODUCTS SERVO DRIVE, 61435110S001
Similar Threads
  1. Replies: 0
    Last Post: 04-12-2019, 12:57 PM
  2. 2014 CX-5 multiple warning lights
    By TeamMurphy in forum CX-5 General
    Last Post: 07-21-2018, 09:57 PM
  3. Replies: 3
    Last Post: 03-12-2017, 04:55 PM
  4. 2015 CX5 Touring - multiple dash lights on
    By MikePlaysGuitar in forum CX-5 Engine & Transmission
    Last Post: 07-13-2015, 08:45 AM
  5. Replies: 6
    Last Post: 11-19-2013, 09:16 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
