Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: Brake Fluid Drain/Fill, Mazda dealer says NO
  1. #1
    Registered Member
    2019 CX5 Reserve AWD
    Join Date
    May 2015
    Location
    Delaware
    Posts
    664
    I called to schedule my 16 CX-5 for service at the dealer. Among the things I wanted done was to drain/fill brake fluid. Mazda service person told me Mazda says not to mess with the brake Fluid? WTF
    I have 24,000 miles on the ODO.
    Thoughts?
  2. #2
    Registered Member
    2017 CX5 GT AWD w/ PP
    Join Date
    Dec 2017
    Location
    New Jersey
    Posts
    92
    I call shenanigans.
    There is no set time to change the brake fluid in your vehicle. The timing varies by driving conditions, but a good rule of thumb is to check it during regular oil changes, and expect to change it every four to five years. Signs that you should get your brake fluid checked immediately include fluid that has a burnt odor, is not clear or transparent, or is at a lower level than it's supposed to be.
    Mine started to turn brown at about 2 1/2 years. I changed it around 40K miles.
  3. #3
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,255
    Dealer probably meant don't mess with it........yet.
  4. #4
    Registered Member
    Join Date
    May 2015
    Location
    Delaware
    Posts
    664
    Quote Originally Posted by CX-5um View Post
    No, I pressed her on it. She said Mazda recommends against changing the fluid. Not sure if they only want it changed when the brakes are replaced or what.
    I'll talk to a tech when I bring the car in next week. This is the only dealer I've ever encountered that refuses to do service.
    They've been a Mazda dealer for at least 40 years. I've bought two Mazda's from them previously.
  5. #5
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    362
    That's ridiculous. It's well known that water in brake fluid leads to poor performance and possible failure of ABS components due to corrosion. Flush the brake fluid whenever water content is 2% or higher.
  6. #6
    Registered Member
    Join Date
    Dec 2017
    Location
    New Jersey
    Posts
    92
    Quote Originally Posted by wlong01 View Post
    Is it possible the dealer was confused with ATF instead of brake fluid?
  7. #7
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,093
    Arrow Brake Fluid Drain/Fill, Mazda dealer says NO
    Thoughts?
    I agree with Arcticshade as usually people say brake fluid flush, but for our SkyActiv-Drive transmission we use drain-and-fill.
    Although it's not listed on our US maintenance schedule, Brake fluid flush is actually listed on CX-5 maintenance schedule with 2-year interval in other regions. We can check brake fluid moisture level, and do the flush if it's 2% or higher.
    For your 2016 CX-5, it won't hurt to replace your brake fluid at this time. It's time, not mileage, as the measurement for brake fluid replacement if you don't check the moisture level. In my experience, I did the first brake fluid change after 20 years at 182K miles on my 1998 Honda CR-V. Like Mazda, there's no maintenance schedule for brake fluid change. There's no ill-effect for the brake fluid after that many years. The only thing I regret is I should get a cheap brake fluid moisture tester and see the moisture level on the 20-year-old brake fluid.
  8. #8
    Registered Member concept's Avatar
    2014 Mazda3 S GT auto, 2008 MX5 6-speed
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,604
    As a general rule of thumb, I have the brake fluid replaced at every brake service. The average humidity here in southern Cali is typically high when the car is in the garage - night and early morning, so that may allow the many year separation between changes without adverse consequences.
    The cost is minimal, so why not have it done when it is most convenient - during change of brake pads? (at minimum)
    2014 3S GT, Deep Crystal Blue, Eibach Pro-Kit, Enkei PF01s, Koni Sports, Pirelli P ZERO ALL SEASON PLUS tires, 225/45/18
    2008 MX-5 Touring (Mazdaspeed CAI, HIDs, Progress/Koni Sports/Racing Beat sways, SST Magnaflow muffler and tips)
  9. #9
    Registered Member
    Join Date
    Oct 2012
    Location
    FL
    Posts
    362
    That would be too long an interval for me. At 7 years 70k my original brakes still had life in them. 3 years is a very good rule of thumb. You really don*t water ruining the ABS components over the long term. Fluid is much cheaper than a brake system failure
  10. #10
    Registered Member
    Join Date
    May 2015
    Location
    Delaware
    Posts
    664
    Quote Originally Posted by ruthrj View Post
    I don't think moisture content is a big worry anymore since the system is tight. I've read that the bigger problem is additive breakdown in the fluid.
    Yeah - can't wait until I ask the dealer to change the ATF fluid. That should be interesting.
  11. #11
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,890
    What do you mean by drain & fill? I flush my Brake fluid when I change brake pads which may be 3 to 6 years and never a problem. Ed
  12. #12
    Registered Member
    Join Date
    May 2015
    Location
    Delaware
    Posts
    664
    Quote Originally Posted by erhayes View Post
    My main objective was to have the dealers service remove the existing brake fluid and put in new fluid. If it requires a flush - fine. I don't care how they do it as long as it's an approved method. Based on what the service writer said over the phone they don't do it per Mazda. It's possible she just sets up appointments and doesn't know what she's talking about.
  13. #13
    Registered Member gova's Avatar
    '14.5 CX-5 Touring AWD, Soul Red | '14 CX-5 Touring AWD White
    Join Date
    Jul 2012
    Location
    IL
    Posts
    521
    People still go to the dealer to let them touch their cars. Here you go...
    Dealers did not touch my cars since new.
    Brake flush done at 44K in both. At least I know what got out and what got in in terms of fluids.
  14. #14
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,604
    Remember that many drivers accelerate and brake more aggressively than others. The mileage and time mean nothing if the number of aggressive actuations is high. I see drivers every day who are accelerating toward a stop sign or red light, and then slamming on their brakes at the last couple of seconds. Their pads will not last nearly as long as my pads will. Also, some people live on steep hills which guarantees more brake wear.
  15. #15
    Registered Member ralf11's Avatar
    Join Date
    Jun 2019
    Posts
    166
    tight? Is the braking system completely sealed and not open to the atmosphere at all?
Similar Threads
  1. Replies: 3
    Last Post: 07-09-2019, 11:42 AM
  2. Drain and Fill ATF once? or again during next Oil Change?
    By FirstOfficer in forum CX-5 Engine & Transmission
    Last Post: 05-22-2019, 01:36 PM
  3. ATF Drain/Fill
    By Chris_Top_Her in forum CX-5 How-To
    Last Post: 05-21-2019, 02:01 PM
  4. m/t drain plug and fill ???
    By dupakupa in forum Mazda6 Engine & Transmission
    Last Post: 12-18-2006, 04:43 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
