Infotainment automatically reboots and changes source to Bluetooth
2017 Mazda CX-5 Touring
I've seen threads claiming that cold weather may impact the infotainment center, but it's 90 degrees F here and my issue also involves Bluetooth. Starting about a week ago, the Infotainment center on my '17 CX-5 will automatically reboot and then automatically change the car's audio source to Bluetooth. This may happen several times while driving. I'm typically listening to FM radio while this happens.
Has anyone else experienced this? I haven't found any threads (yet) on this precise scenario.
What version of software do you have?
Check your MID -> Setting -> System -> About
Unpair your BT device for a few days and see if the problem persists.
If not, you might have a BT compatibility problem.
If so, see if you can update the BT driver on your device.
