In Memory of Member 1338
Results 1 to 7 of 7
Thread: Mazda 3/5 Similarities [interchangeable parts]
  1. #1
    Registered Member
    MAZDA5 09 5spd
    Join Date
    Jul 2019
    Posts
    2
    Question Mazda 3/5 Similarities [interchangeable parts]
    Recently I purchased a used 2009 Mazda 5 MTX to haul people around and have as a daily driver. So far it's been fun commuting to work and packing it up with people on a night out =)
    I'm looking for a good reference to show all or many of the interchangeable parts for the MAZDA 3 and MAZDA 5, since after market parts seem to be very difficult to find for the 5. I have come across it in the forums every now and again, but when I tried searching for it I came up with nothing.
    From my understanding the Mazda 5 shares the engine and some parts of the chassis?
    I'm hoping someone has already listed this somewhere in the forum but if not maybe this thread could help someone else looking for parts
  2. #2
    Registered Member
    2012 Mazda 5
    Join Date
    Apr 2013
    Location
    Vancouver
    Posts
    724
    Some are same, some are different. 5 is not a mod friendly car, get something else if you are into heavy mods and don't want to be the only one doing it
    When you say parts, do you need to repair things or just looking to spend money on stuff for the fun of it?
    when looking for parts, easy enough to look up by your model anyway, I don't think there is a "list" per say.
    rockauto, when you look for a part, it will give what other cars it is used on.
  3. #3
    Booga Booga? phunky.buddha's Avatar
    2009 Mazda5 Sport
    Join Date
    Jul 2011
    Location
    DFW Metro, TX
    Posts
    1,589
    Almost everything in the drivetrain is shared. Suspension, brakes, engines/transmissions to a degree- all can be swapped around. I ended up with Mazdaspeed 3 brakes and rear sway bar, Miata wheels, Mazda 3 2.0 oil filter setup. Think of the 5 as basically a stretched 3 with sliding doors in the middle.
  4. #4
    Registered Member Silentnoise713's Avatar
    2008 Mazda5 Grand Touring; 2009 Honda Fit Sport/Nav MT
    Join Date
    May 2010
    Location
    PA
    Posts
    2,618
    A slightly different question below. Other than the Miata, the Mazda world still has very little aftermarket support.
    https://www.mazdas247.com/forum/show...rts-Fit-Mazda5
    If I had another <10 MTX, I'd do the following, in order.
    MS3 RSB (+endlinks+bushings)
    MS3 steering wheel (or Mz3/Mz5 GT, leather feels SO much better in your hands)
    MS3 gas pedal (unless you don't care to heel toe)
    MS3 calipers (+rotors+pads)
    Taller 5th gear swap (drop HWY rev)
    Stuff for sale:
    YellowSpeed DPS Coilovers - cheap
    ^http://www.wingood.com/flagselect.asp
    My Thread
    ^http://www.mazdas247.com/forum/showt...oise713-Thread
  5. #5
    2009 Mazda5 Sport
    Join Date
    Jul 2011
    Location
    DFW Metro, TX
    Posts
    1,589
    Quote Originally Posted by Silentnoise713 View Post
    I was going to swap the 6 speed transmission over- seems like a better setup for only $1k without having to dig inside for gear swaps. I'm pretty sure I verified that the axles, trans case interface, and clutches were all the same between the 5 and 6 speeds.
  6. #6
    Join Date
    May 2010
    Location
    PA
    Posts
    2,618
    Quote Originally Posted by phunky.buddha View Post
    I dunno. $1K or $200 (realistically <$50 from salvage yard and I'd search for the diesel 5th). The beauty of the 5th gear swap is not needing to dig into trans. You can access the cover by removing drive wheel. The time/effort to drop and swap the whole trans is a lot more effort compared to ~2h labor for just swapping 5th. Incremental benefit at incremental cost I suppose.
  7. #7
    2009 Mazda5 Sport
    Join Date
    Jul 2011
    Location
    DFW Metro, TX
    Posts
    1,589
    Oh right, forgot that the 5th could be swapped from the outside of the case. I was looking to do this back in 2012 when the 6 speeds had just come out.
Similar Threads
  1. Replies: 0
    Last Post: 08-15-2018, 02:55 PM
  2. Interchangeable Brake Parts between Mazda Models?
    By CX-5um in forum CX-5 Wheels, Tires, Brakes & Suspension
    Last Post: 12-25-2016, 12:19 AM
  3. 04 3 parts interchangeable ?
    By c0nfu$3d in forum Mazda3 General
    Last Post: 05-19-2015, 09:20 PM
  4. Mazda 3 and 6 interchangeable parts
    By cdnmazdaguy in forum Mazda3 Accessories & Appearance
    Last Post: 03-23-2014, 09:35 PM
  5. Interchangeable parts
    By Mx6er in forum Mazda6 Accessories & Appearance
    Last Post: 06-06-2010, 04:58 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
