Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: Reusing Crush Washer
  1. #1
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    468
    The oil plug crush washer looked to have plenty of thickness to reuse it. So I reconditioned it, took a couple minutes with tools I had handy. Sanded it on a flat surface with 1200 grit sandpaper to get all ridges out and to flatten it, and then annealed it by hitting it with the torch for a few seconds to make it soft again. I will use it on my next oil change. Yes I know they are cheap but I like to recycle if possible.
    After sanding
    Annealing it
    Finished
  2. #2
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson - southern Oregon
    Posts
    2,221
    Now that's dedication!
    Curious why you felt it should be annealed as well as flattened.
    In the good old days, I'd been known to reuse crush washers with NO preparation, and no ill effects, no leaks. Maybe I was lucky.
  3. #3
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    468
    Quote Originally Posted by shadonoz View Post
    It had some crush marks, and aluminum gets hard when it is compressed. I suppose it might work without doing anything, but for me, it was either recondition it to reuse it, or use a new washer. I don't recommend a crush washer that has crush marks to be reused.
  4. #4
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    362
    Annealing it was a cool idea. Fixes any stress in the crystalline structure from being crushed.
  5. #5
    Registered Member 7eregrine's Avatar
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    5,050
    I don't even know what annealing is, but you are now the Recycle King around here.
    /Bows My Liege.
  6. #6
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,726
    Risks $5400 engine to save $5.40 part.
  7. #7
    Registered Member
    2018 cx5 GT
    Join Date
    Feb 2019
    Location
    BC Canada
    Posts
    71
    Never changed one in my life on any car. Never had a oil leak on any. But they are cheep about .85 cents. Doesn*t hurt to change it.
  8. #8
    Registered Member
    Soon to be 2.5T CX-5
    Join Date
    Jul 2019
    Posts
    71
    Quote Originally Posted by Zeroman View Post
    This is true here as well...
  9. #9
    Registered Member
    2019 Mazda CX-5 Signature
    Join Date
    May 2019
    Location
    Belleair Beach, Florida
    Posts
    68
    God Mazda parts catalogs suck! Trying to determine what the crush washer P/N is for the 2019 CX5 Sig 2.5L Turbo. Of course 2019 CX5 Sig isn't shown, so I try 2018 CX9 Sig and I get down to the part in the diagram Drain Plug Gasket - Mazda (9956-41-400) and it says it fits my vehicle. But down in the description it says "Without turbocharger". WTF???
    So - what Drain Plug Gasket fits a CX5 2.5L Gas Turbo???? Is 9956-41-400 more-or-less universal? The Vehicle Fitment for 9956-41-400 shows it fits 2019 Mazda CX-9 Grand Touring, Signature, Sport, Touring 2.5L L4 - Gas Aren't they turbos?
  10. #10
    Registered Member
    Mazda CX 5 GT-R
    Join Date
    May 2019
    Location
    Occupied California
    Posts
    51
    The Drain Plug Gasket - Mazda (9956-41-400) better fit. I bought two packs of 5 of them off of Amazon for about $7 per pack and am getting ready to do the first oil change on my 2019 GT-Reserve w/2.5L turbo tomorrow. I will report if there are any issues.
  11. #11
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,711
    I just reuse it myself, no leaks so far.
  12. #12
    Registered Member
    Join Date
    May 2019
    Location
    Posts
    68
    Quote Originally Posted by tibimakai View Post
    Yeah, I'm a serial re-user myself (in cars much more expensive) and never had a problem. IMO, the "crush" these washers provide is mainly to prevent stripping the oil-pan's threads. Not to stop leaking. So as long as you take care and don't overdo that final 1/4 turn, you'll be fine. But it's nice to have some spares. Buying one at a time gets cost prohibitive. So I'm probably looking for a lifetime supply.
  13. #13
    Work in Progress sm1ke's Avatar
    Donated: $25
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,611
    Quote Originally Posted by DwightFrye View Post
    That's the correct part number for the washers.
    To anyone freaking out about whether or not the washers are the right ones to use or not, there's a simple solution. Pick up the phone and call the Mazda dealership's parts desk. They can find the correct part for you and provide part numbers if necessary.
  14. #14
    Registered Member
    Join Date
    May 2019
    Location
    Posts
    68
    Quote Originally Posted by sm1ke View Post
    Oh, the same parts department that told me to use 0W20 oil? (Note: I already that's wrong for a turbo).
  15. #15
    Registered Member
    Join Date
    Jul 2019
    Posts
    71
    Quote Originally Posted by St1ngy View Post
    Pretty much.
Similar Threads
  1. Replies: 10
    Last Post: 06-18-2019, 10:17 AM
  2. Crush Washer/Gasket Size ID or anyone have a p/n for Mazda'a (Oil change)
    By Jonesey in forum CX-5 Engine & Transmission
    Last Post: 04-07-2013, 08:41 AM
  3. ATX Fluid Drain -- Crush washer number???
    By wsmallri in forum Mazda6 Engine & Transmission
    Last Post: 05-27-2009, 05:54 PM
  4. Reusing Stock Clamps on Turbohoses HP
    By RenzoMSP in forum Mazdaspeed Protege
    Last Post: 06-20-2005, 07:14 PM
  5. ATV crush
    By crispixoo7 in forum Pics & Builds
    Last Post: 02-25-2005, 06:18 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
