Made in USA and Free Shipping on all orders shipped inside the US.
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: DIY windshield replacement
  1. #1
    Registered Member STudMUffin1177's Avatar
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    321
    So I got a cracked windshield and I'm looking into SCCA RallyCross. They state I need a windshield that's crack free, now I'm also on a heavy budget and don't wanna pay 300 for a windshield. Has anyone pulled and installed one themselves?
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    Yea, I've done it.
    I got a used windshield from a wrecker for $75 and gave a guy at a windshield repair place $20 for a tube of his urethae windshield glue.
    The used windshield was removed from the donor car already but I had to remove my old one. I used a box cutter knife and made all kinds of passes over the same area to cut through it. It's too hard to make one deep cut.
    As it starts to cut through the windshield starts to move and you can see where you need to cut more. I left a lot of the old glue in the opening so I wouldn't run out of new glue and it helps to center the replacement windshield.
    They also have a piano wire type windshield remover where you make a hole through the old glue, feed the wire though from the outside to the inside then saw back and forth to cut the windshield out. (I didn't try that method)
    The biggest problem I had was that I used a cheap ass $2 dispenser gun and the urethane was as thick as tar.
    My gun handle was bending and I had to try to pump the handle with the help of pliers.
    I was squeazing so hard my knuckles were turning white and the nozzle was bouncing around putting urethane every where.
    Once you open the tube, you've only got about 15 minutes before the urethane starts to harden and it will harden up right in your dispenser if you wait too long.
    Get yourself a professional quality dispenser gun like the red one in the picture. Its got long solid handles for more torque and it won't bend or break.
    The Diagram Dude
  3. #3
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    321
    So you just cut it out, line the seam with the glue and then just center the windshield and press it on? Do i have to hold it in place or keep pressure down while the glue is setting? Do you know if the sedan windshields match the wagons? There's no p5s near me but there's a couple sedans in the junkers.
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    Yea, if you cut out your old windshield right at the edge of the glass, the replacement will fit right in and be lined up proper.
    You don't need to hold it but there are plastic supports on the bottom of the windshield that will keep it lined up.
    I put the bottom of the glass on the spacers then rolled in the top.
    It's important to have a complete seal or you will have a leak.
    You can cut a notch (or "V") in the nozzle of the tube to make a wedge of tapered glue so there is complete contact with the windshield.
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    I'm about 90% sure the sedan windshield is the same but not positive.
    Maybe try to cross reference some part numbers.
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    Having someone help you is pretty much necessary.
  7. #7
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    321
    Sweet thanks for the help man, might see this in my thread in a month or so........or a year haha
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    Like this.
    (I had a hard time finding a picture.)
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    The hardest part is knowing you've only got 20 minutes or less to apply the glue and get the windshield set in.
  10. #10
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    Oh..
    And try not to cut into the spacers at the bottom of the windshield. (you kinda know where they are)
    You need them to set your replacement glass on.
  11. #11
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    Worste case scenario is that you end up in Emerg. with a winshield glued to your hands,.. but that rarely happens. lol
  12. #12
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    I missed a couple of spots with the glue when I did mine.
    This spot rusted through a couple of years ago so I sealed it with silicone.
    It's been working fine.
    I had water running into the cab but I sealed the leak.
    This one is new and I intend to clean it up and silicone it too... In a month or year or so. lol
  13. #13
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    321
    That would be one hell of a hospital trip, I rarely wear gloves when I need to and always realize once the 'oh shit this won't come off' panic sets in haha.
  14. #14
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    321
    And man the rust up there is crazy, I've got 2 small spots where yeller got hit with a BB gun but they havnt really spread that much.
  15. #15
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    321
    There's a spot or 2 in the back drivers side fender too but it's all surface stuff
Similar Threads
  1. Replacement Windshield
    By CaribouMainiac in forum CX-5 Accessories & Appearance
    Last Post: 06-20-2013, 10:43 PM
  2. Windshield Replacement
    By Meydron in forum Mazda6 General
    Last Post: 04-30-2012, 05:04 PM
  3. Windshield Replacement
    By JDM-P5 in forum Protege5
    Last Post: 02-06-2009, 06:22 AM
  4. Windshield replacement
    By SkinnyJoint in forum Protege5
    Last Post: 02-15-2005, 11:16 PM
  5. Windshield replacement
    By 2K3 MSP in forum Lounge
    Last Post: 02-21-2004, 08:23 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
